I want more HP, more speed what can I do
Car: 1991 Camaro Z28
Transmission: Built 700r4
Geat different gears in the rear end. That makes your car MUCH chicker. I got 3.73's so i can still cruise at high speeds on the highway but if u want your car to be even quicker get like 4.56's or something....otherwise get a 350...
Car: 1989 Trans Am GTA
Engine: Stock LS1
Axle/Gears: 3.70 9 bolt
I would recommend going to the TBI board, they are the resident experts. But in my modest experience, a good exhaust system is usually the first thing to do. Welcome to the ThirdGen message board
Steve
Steve
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
your never going to get anywhere with your v8 piece of crap
get a real car manyou know a civic DX with some 20" bling blings on there and altezza tail lights
you will be fast as hell then
Car: 1989 Iroc Z L98
get something that will keep you in your power band, 3.73's are as steep as you would want to go for sure.
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
Car: '10 Subaru Forester
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
Originally posted by RMK
Careful rx7speed, he's new and might think you're being serrious. Plus you forgot the trash can exhaust and TYPE-R stickers.
Don't forget the dustpan chin spoiler, the black hood, the windsheild washer LED's, single 22" windsheild wiper and the shopping cart handle!
Car: 99 Formula
Axle/Gears: 342
Car: 99 Formula
Axle/Gears: 342
Car: 85 s-10 soon
Engine: just a small block
Transmission: th350
DO A TBI TO CARB SWAP. ITS EASY AND IT'LL GIVE YOU SOME MORE POWER AND A BETTER THROTTLE RESPONSE. AND IT LOOKS A HELL OF A LOT COOLER THAN FUEL INJECTION YOU'LL NEED AN EGR INTAKE EDLEBROCK SELLS ONE FOR LIKE $130 OR $140 AND THEN GET A CARB. A 600 SHOULD BE MORE THAN ENOUGH. ALSO IF YOU HAVE AC JUNK IT. ITS ONLY DEAD WEIGHT. YOU'LL NEED AN AC ELIMINATOR BRACKET OFF A LIGHTWEIGHT 1LE OR I THINK THIER ARE A COUPLE OF OTHER MANUFACTUERERS THAT SELL ONE.
Car: 1989 IROC-1
Before you do anything decide how fast do you want to be?
What is your budget?
How long can you take building this thing up?
First thing to look at is exhaust. Then you can do simple things like K&N Air filters and such.
Of course a proper tune up is a great idea too!
Car: 99 Formula
Axle/Gears: 342
Car: 2005 BMW 545i
Engine: 4.4L N62B44
then with a carb setup since the venturi is able to be used over a wide band it is only fairly efficient in a smaller rpm range so outside that range you fuel will be pulled in sparadic and will hurt throttle responce, as well as throw your a/f off a bit
and the venturi does create a restriction inside the intake system.
sorry I am hjalf asleep when trying to write this
didn't even ****, shower, or shave yet.
