gas out of tail pipe
1 Post
Car: 87 Formula
Engine: 327
Had a ford ranger come into the shop once with a busted fuel pressure regulator. It was running with gas pouring out of the tail pipe. Crankcase was clear full as well. Replaced the regulator, changed the oil and then prayed that the exhaust didnt catch fire. lol Gas vapor poured out in a cloud for 1/2 hour. I know I should have found a way to drain the exhaust, but....
Anyway make sure its gas. It's probably not, but this could be a possibility.
I'm sure it's just water. I washed my engine a while ago and some water got into the air filter....luckily my car started! The water is all black and smells funny though. probably just because it has been through my engine and exhaust and carb. Thanks
Car: 1986 Firebird
Engine: 2.8 V6
Originally posted by chevymad
Had a ford ranger come into the shop once with a busted fuel pressure regulator. It was running with gas pouring out of the tail pipe. (..snip..)
86CamaroDan
09-29-2015 10:08 PM
