Aftermarket mechanical fuel pump questions
Car: 1992 Camaro Z28 & 2k3 Cadillac CTS
Engine: LB9
Axle/Gears: 3:43
Im looking for an aftermarket fuel pump for my Lg4 and i havent seen any direct replacements, but i have a holley fuel pump itching to be installed. My question is that if i go to install this holley fuel pump, (#12-834) it lacks a return line and also i will have to find the correct plumbing for it. Any suggestions? I heard about a walbro fuel pump, is that for fi cars? Does anyone know what the stock intank fuel pump flows for an Lg4? Should i go to replace that one as well?
Car: 4
Engine: 6
Transmission: 5
AFAIK there is no in-tank fuel pump on LG4 cars.
The stock one is fine up to at least 400 crank horsepower (speaking strictly from experience). You can help it work a whole lot better at high RPMs with a lightweight rod, such as from Moroso.
Engine: LB9
Axle/Gears: 3:43
im pretty sure there is an intank pump on my car, almost positive. im almost sure 87 was the only year they did it. you can hear it whine when i turn the key to the on position.
1 Post
Car: 84 Z-28 Camaro
Engine: 383
Axle/Gears: richmond 3.73, eaton posi
Half year '86's and '87's had a in tank fuel pump not sure what the flow or pressure on it was though
1 Post
Car: 87 Formula
Engine: 327
My 87 formula with LG4 has an intank pump as well as the mechanical. The in tank is very low pressure. But i don't know exact specs. Having both pumps would make me very leery of putting a mechanical pump without return on. The carb needle is going to have to try to stop both pumps. Not knowing what the stall pressure is on the electric pump means you'll probably have a sever flooding problem without the return.
theshackle
03-05-2017 06:37 PM
92camaroJoe
08-13-2015 06:07 AM
