think I should get a cam?
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
just curious if you guys think I should get a full race cam for my RX-7?
Sure! You must make sure you get that super special "3/4's race cam" that I hear all my buddies put in their cars ! It'll make your wankel really really fast!
p.s. Would you care to explain to me what part determins "duration" and "lift" on a wankel ? And can it be changed ?! Sorry I dont know much about Wankel engines.
1 Post
Car: '00 Chevrolet Corvette
Yeah!!! Get some good valves and valve springs to go with it! Don't forget the forged pistons and stroker crankshaft, too!!!
:hail: :lala:
:hail: :lala:
Car: 2005 BMW 545i
Engine: 4.4L N62B44
the reason I have lift in quotation marks is there is really nothing that will lift to let air in
but if you look at the picture I have posted below you can see you can see the intake port on the side of the housing
the rotor on the car spins and opens that up
just look in my sig or my avatar and you can see the motion the rotor moves in and how that would open and close the port
as for the exhaust port that is on the actual rotor housing itself rather then on the side so it is open all the time. though b/c where the intake and compression take place it does not mess them up.
the intake and exhaust are on the same side, just right below the intake
and with the side the port is on the rotor would spin clockwise
Isn't that a 2 cycle
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
If your gonna get a cam, you will need to build the motor up to take it. I would start with a forged crank, connecting rods, and pistons. Then a stud girdle to beef up the bottom end. And while you're doing all this you might as well get a good set of heads. Oh and dont forget the headers and exhaust to make it all sound cool.
:lala:
:lala:
Car: 89 Formula
Engine: Carbed 5.7
Transmission: TKO-600
a cam??? i thought a rotary was just some triangles that exploded and spun? lol i think i will stick to american v-8's lol
1 Post
Originally posted by rx7speed
it is really a 4 stroke :-D
1. Intake - As the rotor passes the intake port and draws the air/fuel mix into the first chamber (or whatever).
2. Compression - As the rotor forces the air/fuel mix into the little combustion area with the spark plugs.
3. Exhaust - As the rotor forces the exhaust gas out of the exhaust port.
Or since there isn't a piston does the stroke principle even apply? Wankels are too weird.
Car: 2005 BMW 545i
Engine: 4.4L N62B44
you forgot about the power stroke
ya know the thing right before that exhaust thingy stroke
and the rotary is not that hard to understand
I promise you that
and even though they are not true strokes so to speak in as in a piston motor it still will have all the different things a piston motor does
I promise you that
1 Post
Now that I really examine your Avatar I think that I get it. There is a time there after the plugs fire that the rotor is moving and not yet to the exhaust port. I guess that would suffice as the power stroke. I hadn't noticed that before.
