Help with cooling fan ????
I have an 86 T/A 305 Carb. stock and I am having trouble with the electric cooling fan. I pulled the fan and direct wired motor to a battery and the motor is working fine. Put it back in and it doesn't work, so I replaced the relay and it didn't help, replaced the two sensors( electric and vacum) on the thermostat housing and still no fan. I am told it is supposed to come on at around 210 degrees. anyone else had this problem? Any advice?
Car: 1986 Firebird
Engine: 2.8 V6
Couldn't he unhook that sensor from the harness, and put a jumper wire between the sensor's harness connector and ground? If the fan comes on then, that fan switch has got to be bad. Right?
Car: 91 firebird,mint
Engine: 305 tbi,lots of work done
Transmission: 700-r4 built by level 10 in nj
Axle/Gears: 3.73, auburn , precision
just direct wire it to your fuse panel so it comes on with the key............i have mine and the tranny cooler fan on the same circuit and running all the time .........2 years no problems
same problem
i have the same problem for my 86 z28 with 305 4bbl. vin g i replaced the same on the thermostat housing and it still overheats so i looked for the switch right above the starter but was told it was a knock sensor
Hey Vader, found the temp switch on the head, bought a new one. Question though? the switch has a hole in the top that looks like it will accept the lone green wire, but is the wire just pushed into the hole and it will stay put,as it looks like that is the only way to connect it, correct??? won't it pull out?? mine is out right now, undoubtably the problem. so I just wonder about the connection........
Car: 86 T/A
Engine: 5.0 TPI
Stock fan turn on temp for an 86 T/A is 234°. If you have the upgraded PROM (you do don't you????) the temp is lower. Check with VADER for details.
