Removing air pump and AC on Serpintine belt
I've got an 88 camaro with a LO3 (TBI) 305. I'm wanting to remove the air pump and the A/C. For the record I don't have emmisions test just have to have a cat. And the A/C doesen't work, besides thats what t-tops are for.
From looking at the car intelf the air pump won't cause any problems the serpintine belt. But with out the A/C pump I won't be able to run a belt.
Does the A/C compressor seperate from the pulley or do I need to buy a new pulley?
I'm just looking to revmove some weight from the front of the car. Free up a couple of horse power. And uncluter the engine compartment.
Any help is greatly apreciated. Thanks In advance.
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: RS
Transmission: 4L60
I kept my ac, but I've seen that most buy a delete pulley, search "delete pulley" or "homemade delete pulley" you get the drift, I'm glad I removed my smog, engine looks way better, where in IL do you live?
part # for the a/c delete pulley from gm is 10055890.
I am going to order mine this week. It is about $45. plus tax.
I posted to get the part # and this is what the guys here said would fit.
go ahead and remove the smog pump. it is just extra weight. besides it makes for more room to work on your motor.
Car: RS
Transmission: 4L60
ha, I played baseball there (think it was baseball) I actually live between amboy and dixon, I'm in peru about eveyother weekend, how far away are you from peru?
Car: 91 RS
Re: Removing air pump and AC on Serpintine belt
Try this
![Smilie](https://www.thirdgen.org/forums/images/smilies/smile.gif)
Car: 1987 IROC-Z
Originally posted by DM91RS
Sorry
I mean try this
Sorry
![doh](https://www.thirdgen.org/forums/images/smilies/doh.gif)
if so, how did you wire it in?
im running a serpentine belt system, and was going to order a a/c delete pulley this weekend, but if i can slap another alternator in their with relative ease, and not need to mess with the bracket, id rather do that....
let me know
sunbound
Car: 91 RS
Originally posted by sunbound
do you have 2 alternators hooked up?
let me know
sunbound
let me know
sunbound
This pic shows the alt bracket cut off the top of the power steering bracket
DM91RS exactly how did u go about making that bracket. what stuff did u use and is it easy to do. thats what i am tryin to do with my car but im takin off the power steering too. but i dont have the cash to lay down big bucks on a March pulley bracket or nuttin but if u could tell me how u made that of some more better pics i would appreciate it very much. thanks
brad
brad
1992 Trans Am
05-10-2023 07:19 PM
backtothe80s
09-05-2015 12:39 AM
mcquigg
08-13-2015 02:26 PM
