Are my plugs gapped too much?
Car: 88 IROC-Z
Engine: 383 Stroker
Transmission: TH350
hard question
Ignition components are in my sig. My plugs are gapped at .052. What are some tangible effects of plug gap being too great? What might you hear or feel?
:hail:IROC-Z
:hail:IROC-Z
Car: 2002 SOM z28
I know it's a hard question. Does anyone know?
IROC-Z
IROC-Z
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Back in the old days of conventional ignition, a plug with a wide gap would result in a good idle, but poor high engine load running; a plug with a narrow gap would result in poor idle, but good high engine load running.
But with today's high output ignitions and the aftermarket stuff available, this rule probably goes out the window.
How easy is it on your engine to change plugs? If it is not that hard then try changing around the gap. Maybe moving down to a .045 gap might work better. A find some one to measure performance not just your butt.
Car: 88 IROC-Z
Engine: 383 Stroker
Transmission: TH350
My sig was listed the first time but then when I edited the post, I must have taken it out. A simple error.
:hail:IROC-Z
89 formula TPI
09-07-2015 11:06 AM
