Gutting engine compartment
Car: 91 Formula, 79 Trans Am, 72 LeMans
Engine: 305 TPI, 6.6, 350 Pontiac
Transmission: T5, 3 speed, TH350
Ok, I need some help here. My motor is in and there are wire looms and other stuff I have no idea what to do with. Plus I have no use for the A/C and heater (Summer car with a/c being windows) So how do I remove all the not needed stuff without worrying about screwing up lighting and keeping the gauges and whatnot working? Any ideas or tips? Thanks
See what I mean:
See what I mean:
You can cut most everything off that's in the passenger side, but the lights and stuff are on the drivers side. I just pulled my motor and whacked a ton of wires. I guess I'll find out if I cut anything I needed when I put it all back together.
Brad...
Brad...
db057
08-11-2015 10:11 PM
