AIR removal
Car: 1990 Trans Am
Engine: Lb9
Transmission: factory T5
Axle/Gears: 3.08 limited slip
AIR removal
im going to remove my air system and just need to make sure itll be okay. I want to remove all of it and every hose, is this okay and will i get any error codes? Anything i should leave on? The car is an 83 lg4/700r4
Car: 91 firebird,mint
Engine: 305 tbi,lots of work done
Transmission: 700-r4 built by level 10 in nj
Axle/Gears: 3.73, auburn , precision
check the tech articles there is an article on smog pump removal...i ripped mine out your car will run fine
Car: 86 IROC
I removed all that crap off of my car, and it runs fine. No codes and cleans up the engine compartment. I can actually see the passenger side of the engine block now!
