which wire goes to tach?????
which wire goes from the ignition to the tach?? i have some tach problems that i need to troubleshoot. also is there any way to test to see if im having problems with the actual tach assembly or if there is somethign wrong with the wiring??
heres some more info on what its doing.
https://www.thirdgen.org/techbb2/sho...threadid=88204
Breathe,
There is a wire from the coil to the tach filter. From the tach filter through the firewall bulkhead connector, the wire is black w/a white tracer. It should continue on the interior side of the bulkhead connector and connect to the left side I/P connector (circuit 121).
eightsixseven
08-14-2015 03:09 PM
