Oil cooler question
Oil cooler question
ok, I used to have DSM, and I know on those if you tighten the oil filter onto the factory cooler too tight it can rupture the grid inside, does this apply to GM's too?? because I got my new 383 back a few weeks ago, and the oil filter was so tight on there I ended up almost breaking the ratchet thing off the bottom of it (K&N filter). . . not to mention this was the old filter off my motor with a knock (tons of metal in it). . . . so basically, when I changed my oil today, all this anti-freeze poured out of the oil cooler, and I wanna know if it could be considere the shops fault, cuz now coinceidentaly, my $4000 383 has a knock after only 60 miles, and I had yet to spin it past 3K RPMs. . . I don't want legal advice cuz the shop will get theirs in the end, I just wanna know if I am justified saying that it was their fault, I mena that filter was on there VERY VERY BERY VERY tight, I had to use locking pliers to get it off, and almost ripped the car off the jack stands putting all my weight into it. . . well thanks guys
![Mad](https://www.thirdgen.org/forums/images/smilies/mad.gif)
well I had the work done at two different places, one place pulled the motor, the other re-built it. I was completely satisfied with the machine work, everyhting went great, and the motor was sent to be put back in with a NEW FILTER (I have pictures). Well me and the shop installing it got into an argument after he broke my headers and I finished the install myself. . so I was all done, went to go prime the motor and had an oil leak (missing pressure sensor) good thing, got under the car and saw the old filter on it. . . sh*t!. so I drain the oil and it was FILLED with metal, it looked like the glitter crap girls put on their face. . so I flushed the motor with fresh oil and filter a few times to get it out and it is all good . . . so I start the motor with just water in it and everything is fine (couldn't see any oil in the water, just looked a lil dirty fron the **** in the overflow tank). . . ran it for 2 days just water before it started to get cold here and I put anti-freeze in it. well today after getting home from work it is sitting in the driveway idling and I hear a hollow knock, can't find it, wasn't the lifters, wasn't the belts, then I realize it is a rod. so I drained the oil to see if there was metal and there was, not to mention it was black with charred anti-freeze after only 50 miles. that's when I took the filter off and my garage floor got a coolant bath
I am pissed, I waited almost 6 months for this thing and I only go to drive it for 2 days!!
![Frown](https://www.thirdgen.org/forums/images/smilies/frown.gif)
anybody else think that is possible?? I was told it isn't on a GM, but there was def. coolant in my oil, and it wasn'tt eh head gasket cuz there was no smoke or overheating.
toronto formula
11-10-2015 06:17 AM
Navy8125
08-21-2015 09:32 AM
