Fuel pump
if its on its way out (depending on how bad it is) you will usually feel it starving for fuel at upper rpms , again if its real bad it could be through your whole rpm range .
if its completly out the car wont run .
also check to see if the digaprham (sp?) is leaking (obviously a puddle of gas underneath your car is not good)
do you have an electric or mechanical fuel pump ? also how many gph is it (if its an aftermarket pump) ?
beachrodder
08-25-2015 08:05 AM
92camaroJoe
08-13-2015 06:07 AM
