no spark what so ever
ok ihave a 1991 trans am/GTA TPI 305 i pulled it under the carport (running) i changed the water pump gasket i went to crank it it will not start it has no spark at all all the fuses are good all four wires going to the coil are hot ibought a new coil same story to be honest iam a datsun/nissan fan ihave never had a f-body none of my datsuns gave me problems like this working on a 1974 260z is totaly diffrent than working on a '91 t/a so any ideas are greatly appreciated p.s any one have a datsunz to trade for a t/a?
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Lol... you can have our old datsun wagon w/ 220 grand on it...
If i had to put money on it, id say it was one of three things. Bad spark coil, bad electronic spark control module thingy, or a dud pick up coil. The best way to find out how to test these things would be to get a helms or chiltons manual... Either way, the manuals are just a good investment.
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
I had this happen to me once. It was on a 95 Talon TSi. Not sure if this will apply but.......
check your cam and crank sensors. if either aren't working you'll get no spark.
Car: 92 GTA/ 00 TA
Engine: 383/350
foreel
Judging by your pic and the db i read on the firebirds I'd say you have a 305 as well unless you dropped in a 350.
RedLeader289
05-28-2019 01:47 PM
HoosierinWA
10-07-2015 10:15 AM
