Radiator size!?!?!?!
ok is there a differance in the 305 radiators and the 350's?? iv got a 305 and im dropping a 350 into it, im hoping the 305 radiator will keep it kool.. any help????
Car: 99 Formula
Axle/Gears: 342
I was mainly asking this so someone else would know. My guess is try it, go with a low stat and fan switch setting. There's no need to waste money if you don't have to. And if it doesn't keep it cool just buy a 3 core aluminum one.
Car: 99 Formula
Axle/Gears: 342
I bought the Griffine 3core aluminum from Summit for $180. I hear Autozone sells one for like $120. Mine doesn't have a drain plug though.
Car: 99 Formula
Axle/Gears: 342
The only reason I swapped radiators when I did my motor swap is because I thought the car was overheating because of the old 305 radiator, but it turned out to be something else.
oohhh, ok.. yeah my 305 never has heating problems, and i dont see why it wouldnt be able to handle a 350.. im also purchasing a 10 1/2'' electric fan for 20 bucks... hope that will keep it kool as well, if not ill just throw that into the van.
Bohemian
08-15-2017 05:11 PM
gta892000
09-16-2015 12:37 AM
