which makes more hp? 383/406/409?
Car: 85 ta ws6 KITT
Engine: Lb9
Transmission: th350
i have a 350 and 400 block. not sure as to which one to use.
which one has the most potential? can a 400 block use 350 heads?
which one would be an overall best engine?
thanks
thanks
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
whichever one revs the highest - probably the 350
but... if the question is which makes the most torque.. 400 hands down. Don't go .040" over if you don't have to..
400 motors need steam holes in the heads.. a 350 head will need to be modified.
Displacement isn't everything in terms of torque. Stroke is the creator of torque so a 383 and 400, or even a 305 and a 350, would be similar in terms of torque. But the bigger bores would give the motors a stronger upper end.
Car: 89rs
Engine: 400Sb
incorrect friend
The stroke plays more of a factor in where the power band is. The rate that the torque falls off on a motor with a 3.75 inch stroke is much faster than a 350
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Any head can be used on a 400 block. You just need a 400 head gasket as a template and drill the steam holes into the new head.
Larger bores create more HP. Longer strokes create more torque. Short stroke engines such as the 302 didn't produce a lot of torque but because of the short stroke and large bore they were able to make a lot of HP at very high rpms. That's why a 305 costs so much to make a lot of HP when compared to a similar 350. The bore is very small.
Comparativly speaking the 383 and 400 will have close to the same torque but the 400's larger bore will make more HP. Since HP is a calculation from torque, the 400 will have a higher torque curve while still maintaining the same amount of torque as the 383. If the 383 makes 400 pounds of torque at 3500 rpm, the 400 would make 400 pounds of torque at 3800 rpm (close enough example).
This is assuming the same cam, heads, intake etc are used on both engines.
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Break out your April 2002 "Chevy High Performance" magazine. Turn to page 75. Read. Understand.
They compared two build-up article engines that produced 500+ HP: a 406 (513 hp @6200, 463 lb-ft @ 4900), and a 355 (527 hp @ 6400, 450 lb-ft @ 5600). Although they didn't actually mount them in a car and make a bunch of passes, they did run the power curves in the Racing Systems Analysis Quarter Pro computer program simulating a 3500# Chevelle.
Results? The 406 got there first, but the 355 was running faster at the end.
Which would you rather be: First? Or faster?
(BTW, bore does influence torque. Torque is force times lever arm {a function of stroke}, force is pressure times area. Bigger area = more force for the same pressure; more force = more torque for the same lever arm.)
Re: incorrect friend
Originally posted by jcb999
That .125" extra bore on the 400 accounts for quite a bit. Your average 383 will make 450-475ft/lbs of torque. A 400 is consistently closer to 500.
mustangman65_79
08-11-2015 03:17 PM
