having a hard time understanding tires
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
call me weird, but i dont understand tires at all
how do you tell the width?
whats the size mean? (sorta know)
i'm really confused and can use a refresher course on the matter
anybody care to offer?
Car: 99 Formula
Axle/Gears: 342
245/50/16s. The first number is refers to the width. And the height of the tire is a ratio of the first number 50% I believe. The middle number I believe is the profile of the tire. And the last refers to what size rim it fits. Anyone feel free to correct me if I'm wrong.
Guest
Posts: n/a
I think tirerack.com has a complete breakdown.
Anyways..
P245/50ZR16
That would be:
P-passenger car (not always used)
245- section width, not overall width, measured in millimeters
50- aspect ratio, which is the percentage of the width that the sidewall height is. So, in this case, the sidewall height is 245*.5 For a 225/60 it would be 225*.6 Pretty simple.
Z- speed rating, theres a whole bunch. For the most part, the lower letters are low speed, higher are high speed. H and I think one other are exceptions. S and T speed ratings, just say no.
R- I think its obvious
16- I think thats obvious too
Truck tires are different (real truck tires anyway), they use what I think is the old tire coding, like my dads truck has Gsomethingx16.5. I never really looked into those codes before, wasnt interested.
Anyways..
P245/50ZR16
That would be:
Car: 87 Grand National
Engine: 3.8 SFI Turbo
Transmission: BRF 200R4
well lets take for an example a 255/50R15 tire. The first number "255" is going to be the measurement in mm from bead to bead (bead being where tire meets rim). The second number "50" is going to be the percentage of the first number "255", this gives the sidewall height. And of course the last number is the size (diameter) rim the tire will fit on which in this case is a 15 inch rim.
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
you want to put money on that mrr23????
wreeeeeeeeeeeent!! Wrong!!
Bead to bead!! Meaning from the bead, up the sidewall, across the tread, down the other sidewall to the other bead. If you don't believe me go outside and measure yours. I worked at sears as a salesman and had training on this!!
not the tread width. not bead to bead. that can change just by putting it on a narrow/wider rim. but ther est is correct.
Engine: 360 HSR
Car: 2006 Silverado 1500
Engine: 5.3L
bead to bead was the correct answer. once again someone with incorrect information correcting the right answer. thanx to the guys though that got it right. if what he's looking for is in inches though, he's going to have to go to the cataloges which are at the web sites or broshure's at the tire stores. i'm not sure though how this is a "refresher course" since it sounds like you never understood it the first time if there was a first time.
Engine: 360 HSR
read here my fellow enthusiasts.
Engine: 360 HSR
and here.
Engine: 360 HSR
and here is one with a picture showing sidewall to sidewall. how much money was on this sears man?? (no4njunk). do i really need to keep proving my answer? no apology needed.
Engine: 5.3L
you obviously still don't get it. first of all if tires were measured by your method of explanation, all 255's would be the same width. the tire is measured from bead to bead, but not side to side. this number starts from one bead and follows the tire around to the other bead. the entire distance it takes to go from one side of the bead to the top of the tire and back to the other bead including sidewall is the distance. it is measured the on the inside of the tire. the 50 series (aspect ratio) would be 50% of the 255 mm is the sidewall. this is why a 255/70 would be taller than a 255/50 yet the is wider. the number is bead to bead including sidewall and top.
Engine: 360 HSR
also section width changes with rim width. as per all the tire manufacturers listed above. every manufacturer even uses a different tread width for their series of tires. some manufacturers in 50 series tires use 75% tread width to section width. other use 80%-90% depending on what the manufacturer wants to make of their tire.
1)Sears man!! First off this is a very reliable source of information considering how many classes I took there. Where did you say you were trained??
2)Zippy is exactly right. I see where you are coming from mrr23 the point is different companies have different methods. I also know that pepboys uses the same method. Why are you saying you don't know everything but you know where to find it. From what you told us you have had a lot of training on this. or was all that . I have gotten my knowledge through experience not websites. Did you go out and measure??? Probably not.
Engine: 5.3L
if i was going to prove it with a diagram i'd use yours. plain and simple, the first number is bead to bottom of tread and sidewall to sidewall measurements added together. example given would be a 255/70 tire. it's sidewall would be 89.25mm tall and 76.5mm wide. all totalling the 255. a 255/50 tire would be 127.5 wide and 63.75 tall. the first number is section size total, not just section width from side to side.
Engine: 360 HSR
Engine: 360 HSR
Engine: 360 HSR
http://www.pirelli.com/en_42/tyres/a...YAAXFYKH5CSFFA
explaining section width being affected by rim width. and section height is from the bead to the highest point of the tread at a given tire pressure. so section height can be changed by tire pressure.
sidewall to sidewall. all 255's ARE the same width. if they werent, you could never reliably change tire brands. as for that argument, bead to tread to bead, my 245 is only 5 inches wide(instead of 9.8x). using a 50 series tire, half the overall measurement would be sidewall.
As such
245-sidewall to sidewall or treadwidth, in mm, pretty much interchangeable unless you oval out the tires (too big for rim) divide by 25.4 for inches
50-sidewall height, aspect ratio, bead to top of tread, i.e, a 255/50r16 is almost EXACTLY 26 inches tall on the rim and inflated, is Exactly ten inches+ 1 mm wide at the tread, and has a 16 inch rim diameter
r16- rim diameter, bead to bead.
sears boy, i can go measure my tire's tread if youd like, but its not 5 inches across, it's 9.6. and it is 26 inches tall. and it isnt a sears tire, its a bfgoodrich. if sears did their tires like that, id need a 610/25r16, just a thought.
As such
Engine: 360 HSR
As such
As such
Sears boy!!! Watch it unless you feel like starting a flame war!! Can you not do math. If your only getting 5 inches then you have a serious problem. Now listen up!! FROM 1 BEAD MEASURE UP THE SIDEWALL ACROSS THE TREAD ALLLLLLL THE WAY OVER TO THE OTHER BEAD. 5 inches huh!! Wow. BTW try measuring the cross section width on different tires and they will be different.
why don't you go and measure your tires and then come prove me wrong.
when did I ever say bridgestone made tires for sears??? Thats right I didn't. But actually they did used to. They were called the potenza.
Engine: 360 HSR
no they currently sell the Apt for trucks but they used to sell a passenger tire which was the potenza. when did I say they would teach other dealers?? Quit putting words in my mouth. Why are you so afraid to go measure your tire. It will take 5 seconds to do!!
Engine: 360 HSR
just to try and help no4njunk out, i went and measured my 225/60-15. from bead to tread 4.5". tread width 8.25" so the total is 17.25" or converted to millimeters, 422.625mm. now 225mm is 9.183". now go out and measure your tires no4njunk. it looks like it doesn't add up to me. the numbers don't match. but if you look real close the tread width of 8.25" almost comes to 9.183". so if i was to get a caliper and measure sidewall to sidewall i bet it would be right at 9.183". but, of course your going to come back and say my tape measure is wrong.
Engine: 360 HSR
Thanks,
Brian
Car: 99 Formula
Axle/Gears: 342
Wow, I was wondering why there were so many posts on this subject. Let's get Vader in here to clear some things up, huh. Nevermind, it was cleared up while I was posting this.
Dear NO4NJUNK, please stop, you are wrong. You are doing nothing to help anyone on this board. If you don't know what you are talking about please keep your mouth shut.
If you would like for me to show you the error of you way please feel free to e-mail me at FaulknerRob
Engine: 360 HSR
I wouldn't say that. I stand corrected!! I know when I'm wrong and I'll just have to take this as a lesson. I'm suprised that sears gave me a book that says that in it (I'll scan the pic from the book as soon as I can). Its been about 3 months since I was laid off so I'm getting rusty. Well it was fun anyway. Kinda sucks how zippy bailed out!! Oh well.
Thanks,
Brian
Thanks,
Brian
Engine: 360 HSR
nothing to help the board huh!! go check out some of my 2xx posts and i'll check out your 51. Then we'll see who's helping the board.
Engine: 360 HSR
Wow dude chill out. Can you not see what I just posted!! I'm wrong ok. I was doing it for arguments sake...no harm done.
Engine: 360 HSR
Ok. I understand. Time for me to go to bed.
Sorry we posted at the same time. I did not mean to come across as a n a**hole but it bothers me when a question turns into a fight. I just hope that the person who asked the question got the correct answer. If not E-mail me and I will try to help. I have a few books here with the info in them but no scanner.
understandable. We weren't fighting but simply arguing. It wasn't meant to be derogatory in any way. This is how adults handle situations...by arguing a point and not flaming. Yeah I kinda feel bad now. I hope he got all the answers but mine I think i'll pm him. later
