Could use cam recommendations
Old 02-04-2002 | 03:08 AM
GTA1327's Avatar
I have an 88 GTA, L-98, stock intake manifold, stock rocker arms, 1,000 cfm throttle body, 24lb/hr accel injectors, 3.73 rear (but looking to go 4.10), T-5 transmission. Biggest thing is the engine has 165,000 miles on it, all original, but it's been babied most of it's life and runs suprisingly strong. I am looking to get better valve springs along with 1.6:1 roller rockers. I'm unsure as to whether a cam is a good idea at this mileage and how radical i can go without the computer giving me problems. I am also looking for for something that might possibly give me the good high end and sweet idle I've been chasing after since I bought the car. Hell, if you know of a good intakes off hand, I'm listening. I'd like to make some good power after 5,000 rpms. Any suggestions? Thanks.
Old 02-04-2002 | 10:25 PM
zippy's Avatar
Car: 2006 Silverado 1500
Engine: 5.3L
after going over the parts you have to work with i'd recomend 1.5 ratio rockers and either XR258HR comp cam or powermax 2031 crane. with the crane i'd recomend 1.6's and deffinitly new valve springs on either.
Old 02-04-2002 | 11:03 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Yea theres alot of cams that do well over 5,000 , but your intake and heads are not up to the task of anything over 5000. I'd look for a 1500-5500 cam. I went with a XR269 cam 218/224 .496/.503 112 LSA On my 350 TPI
Old 02-05-2002 | 06:54 AM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
http://www.compcams.com/information/...on/default.asp
Prodigious
Theoretical and Street Racing
35
04-13-2021 03:37 PM
Jorlain
10-08-2015 02:57 AM
customblackbird
10-01-2015 05:30 PM
Strick1
09-04-2015 08:11 AM
masonta
09-01-2015 07:40 PM
Quick Reply: Could use cam recommendations
