lt1 or crane
Car: 89 Formula
Engine: Carbed 5.7
Transmission: TKO-600
lt1 or crane
should i go with the lt1 cam witch i hear has a 118 lobe seperation witch would make for a real smooth idle. or should i go with cran cams compu cam 2031 with a 208/214 duration @.050 lift and a .438/.452 gross lift. it also has a 112 lobe seperation. which one would i get better performance out of and witch one would idle the roughest?
I thought the LT1 had 112*? Those lift numbers are nearly identical to the LT1 cam with the LT1 being every-so-slightly more aggressive. I'd stick with the LT1 and spend the money you'll save on other mods... or food.
Car: 89 Formula
Engine: Carbed 5.7
i'm gonna go with the lt1 cam cause i just called sumit and the crane is 250 bucks and i coudl get an intake and the lt1 cam for under that. do u know if the lt1 cam give your car sumwhat of a rough idle or no. also is there any certain lt1 cam i should look for like year or anything. b the way its going in a 305 tbi if that means anything.
I've got a 96 LT1 cam in my L98(205/207@.050".447/.459 LSA 117 deg.)with a set of 1.6 roller tips.Once it is warm it idles @ 600 RPMs and is agressive sounding,but above 600 it is pretty smooth.It's hard to tell what I gained from the cam because when I rebuilt the engine I bumped the compression up, hogged the snot out of the heads,ported the intake system,and installed a 2500 stall converter.All it does is spin the tires,but I'm satisfied so far.
Hotrodboba400
12-10-2019 07:07 PM
88SS6SPEED
11-11-2015 07:05 AM
