Opinions from the engine builders
Old 01-30-2002 | 07:21 PM
tpi_roc's Avatar
Ok guys, im looking for over the year experience on bearings.
Cleavite, federal mogule, or otherwise?
So far i've spun 2 federals. And I've messed up a full set of cleavites on the bottom end, and spun the front cam bearing out the block
Whats the BEST BEARING???
Old 01-30-2002 | 07:47 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
I like Federal Mougul, I havent had any problems with them. It sounds like the cam bearings were installed improperly and your rod and main bearings were not the proper size. Has your crank been turned? If so how far did they take it? Anything over (20 under) is too far for my taste and most other builders. The guy who does my cranks doubles the price and cuts the warenty off for a crank that needs to be turned 30 under. What it sounds like with the cam bearings is the feed hole was not alligned with the oil passage enough and thats why that one spun. I have the maching shop install my cam bearings even though I have the tool avalible to me.
SSC
Old 01-30-2002 | 08:00 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
i would start looking for another block
if you had all these problems with the same one, its mostlikely not bearing relating.
Old 01-30-2002 | 08:20 PM
tpi_roc's Avatar
Little off topic guys
Just wanna know what the favorite brand is
(side note it wsn't the same block)
((and no the crank wasn't turned))
Old 01-31-2002 | 12:07 AM
Guest
Guest
Posts: n/a
Clevite.
Federal Mogul=budget stuff.
Old 01-31-2002 | 08:01 AM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
GM morain 400
but you can't get them anymore I don't think.
Clevite H-vandervill series (for bigbuck race engs)
and P series for rebuilds
Old 01-31-2002 | 10:12 AM
tpi_roc's Avatar
The H-series is what I'm building on now
Glad I didn't pick otherwise
Old 01-31-2002 | 05:22 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
autozone game me some clevite ones last year when i did an overhaul. werent that expensive either.
Old 01-31-2002 | 06:06 PM
ede's Avatar
ede
preformance C&A, for a normal rebuild i use federal mogal
Old 02-01-2002 | 05:16 PM
tpi_roc's Avatar
trudat
Old 02-01-2002 | 06:13 PM
Inwo's Avatar
Car: 2007 Saturn Sky Redline
Engine: 2.0 turbo
Transmission: m5
Axle/Gears: 3.91 LSD
Looks like we have a real winner here :-(
Need some gear oil?
Old 02-01-2002 | 08:40 PM
arthur's Avatar
Clevitte 77
These are recommended by Smokey Yunick. They have a hardshell yet have a soft enough surface to absorb particles into the bearing, and thus save the journals. The most important thing is to get proper bearing clearances, no more than 0.003"! Also that spec is for the perpendicular center point from the parting lines of the shell. At the parting lines, there is more clearance to allow the main caps to flex, which pulls the shells into the journal and starts to scrape off the oil. Mr. Yunick also discovered this phenomina and the bearing manuf. started to create them in this fashion. Shoot for about 0.0025"
onefreakz
05-14-2018 12:15 PM
camaro71633
09-01-2015 10:24 AM
porkenstein
Convertibles
08-31-2015 12:54 PM
bradleydeanuhl
08-12-2015 11:48 AM
1992 Trans Am
08-09-2015 04:32 PM
Quick Reply: Opinions from the engine builders
