why does my 1990 350 idle at about 35 -40MPH
i have a 1990 350 with 373 geats, and it idles through town at about 35 - 40 mph obviously this is hard on my breaks and gas milleage. im knew to cars and only got it last summer, and after a new starter, tranny, fule pump, breaks and a complete coolant rewiring, i was just about maxed out so i had no more money, not even enough for a mechanic to twist another bolt so i left the problem unchecked. i dont think its to much but any help would be great.
You idle at 35-40mph??
Do you even use the gas pedal to get around town, or just let the idle pull you around??
Thats insane, mine I don't think reaches 5mph at idle.
Check the idle screw, make sure no one messed with it.
1 Post
Car: 99 Formula
Axle/Gears: 342
I would say check your throttle return spring, make sure it doesn't have any kinks in it. You think 35-40 is bad, one day I had taken the air cleaner off and put it back on. Somehow I messed up the return spring. As I left for work I nailed the gas and then let off. Well, my foot was off, but my car was doing 50 mph and gaining speed. I slammed on my brakes, finally after slowing down on the shoulder, I put the car in Park and real quick turned the car off.
And for the sake of the safety of others get it fixed.
1 Post
Car: 91 Red Sled
I'm in the same boat. My car idles the same speed and I too have 3.73 gears. I know it isn't my IAC because I watch it and my return spring on my TB unit is huge. No problem with min idle either because when I come to a stop she idles at 700rpm smooth with a little stumble. Most likely your car is running slightly rich and a lot of base timing. I know I am. The rich low rpm makes for more low end torque and the advanced timing makes the engine want to keep a high idle more torque. You should see my car, it's pathetic, I usually just give it a little gas just to get going faster than the cars behind me then I drive around the parking lots with my brake.
:lala:
Unless you burn your own eproms the only thing you can do is adjust base timing and fuel pressure. I don't advice touching either because you're probably running very strong performance wise and it would be stupid to say some $40 brake pads are worth you loosing stop light races
:lala:
Sanjay
08-12-2015 03:41 PM
