Larger than normal schrader valve in R12 high side port?
So I'm in the process of going through the AC on my car, and I can hear the port on the high side leaking. But I can't remove the valve because it has a super long stem that seems wider than normal? What kind of tool do I use to take this out, and is it actually a different size schrader valve?
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Larger than normal schrader valve in R12 high side port?
I have one of these in my toolbox.
https://www.ebay.com/itm/A-C-Schrade...C/173954650820
There's also a tool that allows you to replace the valve without evacuating the freon.
Engine: LB9 305
Transmission: AT
https://www.amazon.com/Diking-Condit...0217133&sr=8-5
How would such a tool allow changing the Schrader W/O venting the refrigerant?
Engine: LB9 305
Transmission: AT
I would not think so.
