Fuel Tank Vent Valve (again)
Old 07-07-2021, 12:55 PM
  #51
TGO - 10 Year Member
OrangeBird's Avatar
Car: 1989 Firebird
Re: Fuel Tank Vent Valve (again)
I just ordered one myself, even though mine is OK right now, when unobtainable parts all of a sudden become available, best to strike while the iron is hot
IROCThe5.7L (07-09-2021)
Old 07-07-2021, 05:43 PM
  #52
Tuned Performance's Avatar
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Post#70 was making these
https://www.thirdgen.org/forums/hist...t-valve-2.html
Old 07-07-2021, 07:12 PM
  #53
355SS's Avatar
Car: 90 Camaro
Engine: 418 LS3 whipple charged
Transmission: Magnum T56 w/ Street Twin
Axle/Gears: 3.27 9 bolt
GM used this valve again on the 97-99 corvette
Old 07-07-2021, 07:58 PM
  #54
bensbaby's Avatar
Car: 1988 GTA Trans am 1 owner since new
Engine: 383 built
Transmission: 1995 camaro t56 6 speed
Axle/Gears: 3.24 posi 9 bolt
I don't think it's a bad vent valve
I think you got rust chunk in the gas tank fill vent I think you should get a borescop on eBay and app on your phone 12 bucks and stick it down the gas tank filler neck there are 2 passages the small one is a vent it could be a mouse dead
gl
Old 07-10-2021, 03:54 PM
  #55
OrangeBird's Avatar
Car: 1989 Firebird
And here it is, in all it's glory, the previously made of unobtainum "Damned Dangling Dingle of Death" , er, I mean the fuel tank vent valve, of course
Ordered on the 7th, delivered on the 10th (Kudos to Hawks for making it available in the first place, and for the 3 day shipping) , and into the spare parts closet it goes, hopefully to never be seen again.
I figure just having it around, waiting, will be enough to keep the original one in the car from screwing up
LiquidBlue (07-10-2021)
Old 07-10-2021, 05:34 PM
  #56
LiquidBlue's Avatar
Car: 90 Formula / T-tops
Transmission: MD8
Dang Orange, that was some fast shipping! You might wannna keep it quiet around here, someone may get desperate and break into your garage to get the unobtainium !
OrangeBird (07-10-2021)
Old 07-10-2021, 06:24 PM
  #57
OrangeBird's Avatar
Car: 1989 Firebird
I gotta admit to a bit of a parts hoarding thing going on, I've got more spare parts for my Firebird than I've ever had for any other car I've owned. It's so bad that most times when I need a part I buy two, one goes on the car and one goes in the parts storage. I know it sounds a bit psychotic but I use my car as my daily driver, and I'm always worried about what the next part to become extinct will be, like our delay wiper motor cover/circuit board that isn't readily available, And so, yeah I hoard stuff
1989karr (07-12-2021)
Old 07-11-2021, 01:31 AM
  #58
LiquidBlue's Avatar
Transmission: MD8
Love it!
Old 12-09-2021, 02:28 PM
  #59
LiquidBlue's Avatar
Transmission: MD8
What should the installation orientation of this valve be? e.g., which end points towards open air? (haven't been down there to look yet) Beginning to wonder if mine was installed backwards. Parked the car the other day, and could hear it releasing air.
Old 12-09-2021, 02:34 PM
  #60
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
the white part faces downward and attaches to a bracket. the other end attaches to a hole that goes up to the sending unit and i guess allows air in or something?
Old 12-09-2021, 03:01 PM
  #61
LiquidBlue's Avatar
Transmission: MD8
Thanks - guess that would be pretty hard to install backwards! Now I understand why it has a 4 prongs on that end.
Old 12-09-2021, 03:05 PM
  #62
1989karr's Avatar
Engine: 3.4 / 5.0
no prob!!!
Old 12-10-2021, 11:49 PM
  #63
3rdgenzroc's Avatar
Car: 86 Iroc-Z
Engine: 383 HSR
Ekler's/ Ricks Camaro/ Brock's Camaro/ Hawks, have all had them for a while... But, Hawks is a sponsor!
Old 12-11-2021, 02:12 PM
  #64
B88185918's Avatar
they sell the fuel tank new at ebay and at hawks motor sports.
Old 10-19-2022, 11:29 PM
  #65
SlickVick's Avatar
Car: 92 Camaro RS
Engine: 3.1L V6, stock
I have a 92 that had the fumes leaking into the car from the filler tube. I was able to seal that but now the thing won't stay running. Could the vent valve be bad but the holes I sealed were letting air in to take its place?
Old 10-20-2022, 09:37 AM
  #66
LiquidBlue's Avatar
Transmission: MD8
What do you mean by won't stay running? Will the car stay running if you remove the gas cap?
Old 10-21-2022, 12:25 AM
  #67
SlickVick's Avatar
Car: 92 Camaro RS
Basically will crank and run, but after just a few minutes, with a light load, like stopped in gear at a stop sign, it will cut out and go dead.
Haven't had time to try with no cap, but it ran fine before I sealed the vapors out.
Old 10-21-2022, 08:57 AM
  #68
LiquidBlue's Avatar
Transmission: MD8
could be a coincidence. try it w/o gas cap to rule it in/out. I would also look close at your entire evap system after making sure it runs with the gas cap off.
Old 10-21-2022, 01:22 PM
  #69
1989karr's Avatar
Engine: 3.4 / 5.0
Itd take a while for the vacuum to get strong enough to prevent the fuel from flowing... mine took about 1- 2 hours of driving. Then when the cap was released you could actually here the tank imploding / popping back out cause the vacuum was so strong.
Back in the day i went driving and around here there are a lot of military roads... got stuck turbning around at one of the military gates ...it was kinda embarassing getting out and releasing the gas cap
Old 10-21-2022, 03:53 PM
  #70
SlickVick's Avatar
Car: 92 Camaro RS
Yeah I been trying to spruce it up, full tune up done just thought it strange it happened at the exact time I fixed the other. Fuel pressure shows steady 45 but I haven't had it on when it starts dying though
Old 10-21-2022, 04:48 PM
  #71
1989karr's Avatar
Engine: 3.4 / 5.0
As soon as it starts dying, get out and release the cap and see if it helps
Old 11-03-2022, 02:54 PM
  #72
SlickVick's Avatar
Car: 92 Camaro RS
Ok so this is not my problem, just a coincidence. I pulled codes and got 22, 23 and 34. First two are possible short to ground for tps and iat. Do these share a common ground, and if so can I just run a new ground for them. 34 is map sensor but that may have triggered from the crazy low idle the first two are causing.
Any ideas would be appreciated
scottmoyer
08-01-2020 01:11 PM
R-Dog
08-24-2019 11:30 AM
camaro1992
07-27-2007 10:33 PM
3.8TransAM
12-27-2001 01:23 PM
Quick Reply: Fuel Tank Vent Valve (again)
