92 z28 5.7 tpi help !
Old 08-01-2017, 02:29 PM
LittleFranks's Avatar
Car: 92 Z28 Hawaiian Orchid
Axle/Gears: 3.23 Posi
so..
Im having this MAJOR problem in my Hawaiian orchid z, the car will not run right. idles fine, but as soon as i give it some gas.. the car stutters and wants to stall out. Ive changed plugs and wires, car has headers so all the smog stuff is gone, reset the timing to 6* BTC. It started out of no where about two months of owning the car and every day driving. when i first noticed it happening, i went to make sure it wasn't a timing issue and noticed the previous owner didn't tighten the dist. hold down tab and it was spinning.
fuel pressure is good
timing is good
fuel filter changed
fuel pump was replaced a few days before purchase by previous owner
i have no clue whats going on and it stumped me.
only thing left to check is the points/coil and the injectors.
any help is appreciated, thank you !
Re: 92 z28 5.7 tpi help !
also, as soon as i put the car in drive, it stalls.
Old 08-01-2017, 02:31 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
No points. Check your TPS
Old 08-01-2017, 02:35 PM
Tootie Pang's Avatar
Car: 1989 IROC Convertible
Engine: 350 TPI L98
Transmission: WC T5
and MAF
Old 08-01-2017, 02:36 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
and MAF
No MAF on 92
Old 08-01-2017, 03:07 PM
cardo0's Avatar
Car: Fourth Gen '94 camaro
Engine: 350 Gen II
Transmission: A4
Always check the diagnostic trouble codes DTC. A real time scan is even better. Before you start spending money on parts get a dealership diagnoses.
Let us know what you find.
Old 08-01-2017, 04:17 PM
Engine: 350 TPI L98
Transmission: WC T5
Originally Posted by Bob88GTA
No MAF on 92
Well we can check that off then!
Old 08-01-2017, 05:49 PM
Checked codes today, received a 22 and 32 code.
Old 08-01-2017, 06:04 PM
tealman92's Avatar
Car: 1992 Z28
Engine: 383
You say fuel pressure is fine. What is it at at idle?
Old 08-01-2017, 06:16 PM
TGO - 10 Year Member
Tuned Performance's Avatar
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
You might want to diagnose the code 22 first over the egr error.
http://chevythunder.com/tps_code_22.htm
Old 08-02-2017, 09:30 PM
I rock 88's Avatar
Car: 1989 RS Black Vert
Engine: 305 TBI
Axle/Gears: 2:7some thing
I would be looking for a vacuum leak.
One way to check for vacuum leaks is while the car is parked and idling you can spray WD-40 / starting fluid / something in that family. Spray around the engine bay with motor running and listen for RPM changes and that's where the leak will end up being somewhere in that vicinity good luck
Old 08-04-2017, 11:36 AM
cardo0's Avatar
Engine: 350 Gen II
Transmission: A4
Code 22 is throttle position sesor voltage low.
Code 32 is EGR system malfunction.
What you really need is a shop manual that shows you how to test and verify those problems so you can correct them. You can also use internet searches but it's something you need to sort out yourself.
Good luck and let us know if you have any specific questions.
Old 08-11-2017, 02:21 PM
Update :
pulled he gas gas tank and replaced the pump with a high volume pump. Car runs flawless now ! Thanks for all the help everyone
Old 08-11-2017, 02:31 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Thanks Franks for the update! Normally we are left hanging!
