what did you do to your thirdgen today?
Old 04-07-2021, 02:40 PM
  #1551
1986BANDIT's Avatar
Car: 1986 trans am
Engine: 305/350
Transmission: 5 speed
Re: what did you do to your thirdgen today?
swapper,you are slipping.usually you update with new progress every other day
Old 04-07-2021, 04:46 PM
  #1552
Swapper's Avatar
lol i stopped posting here and just made a build thread. didnt think anyone cared. i just post in the build thread in case my stupid computer decides to kill itself and i lose all my pics. had that issue a few times. i hate computers.
BUILD THREAD <<< click that
The following 2 users liked this post by Swapper:
1986BANDIT (04-22-2021), Clemson327 (04-21-2021)
Old 04-08-2021, 08:03 AM
  #1553
Moonlight137's Avatar
Car: 1992 RS
Engine: L03 / MSD / 2½" "hacksaw" catback
Transmission: 4L60
Originally Posted by 1986BANDIT;[url=tel:6421606
6421606[/url]]you got a modern 3 cylinder and 10 speed auto in your camaro? 28 mpg?? what? even my 2016 4 cylinder doesn't get mileage that good.<<<<(i do this quite often though)
i guess 2.73 granny gears ,all highway driving keeping it at 1200 rpm and a 700r4 really help but having driven a 2.73 rear 305 camaro for 10 years i dont remember ever getting 28 mpg .nice!!
I was way off! It was only about 24-25.
Old 04-18-2021, 11:54 PM
  #1554
Carnage87's Avatar
Car: 89 GTA
Engine: 5.0
Finally finished the bodywork and sprayed 2 coats of epoxy I had gotten back down to bare metal again in so many areas. If it warms up tomorrow like it should be will get the 2k high build on and off to block sanding!
The following 2 users liked this post by Carnage87:
Old 04-21-2021, 06:21 PM
  #1555
Clemson327's Avatar
Car: 1985 Z28
Engine: 383
Axle/Gears: 10 bolt/3.73
I finished up the air pan to seal to my Sunoco hood from Hawk’s. Ignore the unplugged spark plug wires.
The following 3 users liked this post by Clemson327:
1986BANDIT (04-22-2021), DynoDave43 (04-24-2021), NoEmissions84TA (06-18-2021)
Old 04-22-2021, 03:29 PM
  #1556
82firebirdlove's Avatar
I have been fighting my windshield wiper for 2 weeks now. I have changed the motor added extra ground and nothing helps. This is what it is doing.......I can unbolt the motor and connectors, then revolt and it works for just a min. When I turn them off. They will not come back on again. Can someone please help me. 82 firebird
Old 04-22-2021, 08:21 PM
  #1557
1986BANDIT's Avatar
Car: 1986 trans am
Engine: 305/350
Does the wiper motor work properly when you power it up to 12 volts but not connected to the car? if it does ,it seems like you may have a faulty switch/wiper stalk or wiring is wrong somehow,possibly a short.is your wiring a mess in the car,did someone cut,snip ,remove,alter,screw with and/or pretend it was a race car at any point,messing with the systems of it? mice eaten harness? could be one of several things,make sure the wiper motor works properly independant of the car,then troubleshoot what is wrong with the rest of it if it checks out.check each wire for continuity from the motor to the switch,i know its a pain but its the only accurate,foolproof way to troubleshoot it.
theraymondguy (01-31-2022)
Old 04-22-2021, 08:23 PM
  #1558
1986BANDIT's Avatar
Car: 1986 trans am
Engine: 305/350
ive got to build one of these for my cowl hood,this one looks great though
Clemson327 (04-23-2021)
Old 04-22-2021, 08:25 PM
  #1559
1986BANDIT's Avatar
Car: 1986 trans am
Engine: 305/350
i looked forward to and read every post you made,how is it going.did the turbo setup ever get started? you were the reason i actually participated in this thread
Old 04-22-2021, 10:06 PM
  #1560
Swapper's Avatar
lol yeah turbo kit got built. i literally jsut picked up my headers form getting ceramic coated. so turbo kit is gonna go back together this weekend then i can finally burp the cooling system, make sure the holley setup is happy. unfortunately im trying to sell my old wheels cause i got some c5 z06 wheels so i have no wheels with tires on them yet. got alot done since last post. tubo kit, swapped my 12 bolt in, plumbed the a/c setup (still tryin to figure out the wiring) bunch of little stuff here and there.
The following 3 users liked this post by Swapper:
1986BANDIT (08-15-2021), Clemson327 (04-23-2021), Moonlight137 (08-15-2021)
Old 06-18-2021, 06:08 PM
  #1561
gscroll's Avatar
Car: 91 Z28
Engine: L98 5.7L 350 TPI
Transmission: It works.
Well after 10 months of my car sitting in mothballs I (along with a buddy of mine) was finally able to get it running again after changing out the following:
new 3 core radiator
new heater core
new vortex style fans with fan shroud
rewired fan harness
new transmission cooling lines
New oil with filter
new battery
these fans are a beast! The temp didn’t go above 180! All I’m missing now is a new upper radiator support since the old one will not fit anymore, and will come sometime next week!
The following 3 users liked this post by gscroll:
1986BANDIT (10-24-2021), Clemson327 (06-18-2021), NoEmissions84TA (06-18-2021)
Old 06-19-2021, 11:51 AM
  #1562
Hawkeye1980's Avatar
Car: 1989 Firebird Formula 350
Engine: 5.7
Axle/Gears: Stock
Start wet sanding the back end and spoiler for its 3rd repaint...Arrggghh...
Old 06-20-2021, 11:14 PM
  #1563
mjensen71's Avatar
Car: 1991 camaro rs convertible
Engine: 3.1L v6
Transmission: 5 speed manual
i replaced the entire steering linkage, from the ends of the outer tie rods to the center link to the idler arm and pitman arm. Pitman arm puller with impact wrench made life a lot easier after using a torque wrench to loosen it from the steering gear box. didnt quite put it back the way i took it apart, but i got the tires back on and it off the jack stands and ill fine tune it in a few days when the heat dies down and then deal with rest of the front end suspension and struts/ball joint replacement.part of my sons project.
Old 08-15-2021, 01:35 PM
  #1564
Car: 1992 RS
Transmission: 4L60
Re: What did you do to your thirdgen today?
After moving from San Diego CA area to Amarillo TX area 4½ months ago, I introduced her to her first real hailstorm.
Edit: More dramatic view (You can also see my window corner crack, and of course PO's peeling primer.)
Old 08-15-2021, 04:59 PM
  #1565
1986BANDIT's Avatar
Car: 1986 trans am
Engine: 305/350
jeez,thats brutal ....my soft old 35 year old paint wouldnt like that much,not that it looks a whole lot better....ive been contemplating a nice respray in refrigerator white(or whatever is durable,shiny and relatively cheap) for a while now
Moonlight137 (08-16-2021)
Old 08-15-2021, 05:04 PM
  #1566
1986BANDIT's Avatar
Car: 1986 trans am
Engine: 305/350
Swappers car is one of my favorite builds...wish i had the ***** and money to go turbo ls ...my non working family kind of takes its toll
...im lucky to afford gas occasionally.the alternative is to spend double/triple on rent elsewhere and not have a garage so im kind of stuck and it
pisses me off to no end.my rant is over,off to go feel sorry for myself.
however i did get my koni yellow struts in and finished off the engine compartment(for now with my limited resources)
after...
before...
dmccain (10-13-2021)
Old 08-15-2021, 05:52 PM
  #1567
COTM Editor
TGO - 10 Year Member
QwkTrip's Avatar
Received 1,941 Likes on 1,325 Posts
Car: '89 Firebird
Engine: 7.0L
I like how you painted the heater box white to match the firewall. Looks cleaner.
1986BANDIT (10-04-2021)
Old 08-15-2021, 06:21 PM
  #1568
1986BANDIT's Avatar
Car: 1986 trans am
Engine: 305/350
this is when i first looked at it back in 2017,surprisingly this was in February in Canada...
thanks,that was my train of thought.i got lucky and found a close match in spray bombs.
that's also how i painted my hood and the heritage wing.its just a quick ,not so perfect
fix but at least it all appears to be one color if you don't look really closely...
its a 10/10 looks like a 10 from at least 10 feet away,lol.
dmccain (08-25-2021)
Old 08-25-2021, 01:30 PM
  #1569
Carlos89's Avatar
Car: 1986 Trans Am
Engine: 5.0 LG4 4BBL
Transmission: T5 5-Speed
Today I'm installing my rebuilt Quadrajet back in my TA. I just finished replacing all the spark plugs except 6 and 8. The Hooker headers dont make it fun. After trial and error with a bunch of tools, it turns out a simple offset box end wrench did the trick. 6 and 8 look like an underneath job so I'll do that tomorrow.
Old 08-25-2021, 02:23 PM
  #1570
1986BANDIT's Avatar
Car: 1986 trans am
Engine: 305/350
if you have a carbed third gen(which you do) just use a spark plug socket and a wrench on the end of it.sometimes you can also use a wrench or modify the socket and make it shorter.
chances are the plugs you missed were missed by the last owner too so they are fubared...if you have hooker 2460 headers it should be no issue whatsoever,i easily changed all 8.
of you have air conditioning the rear passenger side plug is a real b itch but worth doing and isnt as hard with the ideas i mentioned.
Carlos89 (10-06-2021)
Old 08-26-2021, 10:47 PM
  #1571
NoEmissions84TA's Avatar
See attached.
Attached Thumbnails what did you do to your thirdgen today?-sp-socket-3.jpg   what did you do to your thirdgen today?-sp-socket-2.jpg   what did you do to your thirdgen today?-sp-socket.jpg
The following 2 users liked this post by NoEmissions84TA:
1986BANDIT (10-04-2021), Carlos89 (10-06-2021)
Old 08-31-2021, 02:55 PM
  #1572
kennyglm's Avatar
Car: 87 irocz
Engine: 5.0
i dusted mine off because it just sits there collecting dust like a knick knack
Old 09-06-2021, 10:55 AM
  #1573
Car: 1992 RS
Transmission: 4L60
I replaced my hatch pulldown.
I found one cheap on FB that someone had taken off a late-91, but didn't fit because his is an 80s car. I grabbed it for my 92.
He was a little sarcastic when I asked for more info, and just repeated the little that was already in the listing. But I gritted my teeth and went for it, and fortunately it works great. Now I'll find out what's cracked in the old one, and see if I can 3D print it.
Old 09-07-2021, 01:10 AM
  #1574
taonindo's Avatar
Car: 82 firebird
Engine: 406
Right turn signal wasnt shutting off , pulled the wheel and rebent the spring ... works now or shuts off. Biggest thing put fuel in ... $50 to fill up, it is getting crazy.
Old 09-07-2021, 06:54 AM
  #1575
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
I tried to install my new Proform Polished Slant Edge centerbolt valve cover to find out my AFR heads have shallow bosses. I didnt find out untill I snapped a bolt off between the cyl #7 valves. Still trying to remove the broken piece.
Old 09-08-2021, 01:09 AM
  #1576
OUCH!
Old 09-15-2021, 07:07 PM
  #1577
GreenieG's Avatar
Car: 1985 IROC-Z
Transmission: T5 manual
doing some body work in preparation for layin down some primer soon, been trying to get out into the garage and do an hour or so a day.
DynoDave43 (09-15-2021)
Old 09-15-2021, 08:36 PM
  #1578
1986BANDIT's Avatar
Car: 1986 trans am
Engine: 305/350
the better the prep,the better the final paint.....
Old 10-03-2021, 08:52 PM
  #1579
Engine: 5.7
Axle/Gears: Stock
ran new speaker wire to all the 4 locations, started setting up the new radio but the connector I bought is garbage. So I ordered an 8 port blade connector off eBay for the 4 speakers. I have to by pass the factory amp, it wont play nice with my 2 din radio, which has an amp built in anyway. I hate cutting factory wires so I am leaving the existing wiring in place with the connectors. New set of Pioneer 4x6s and 6x9s will be installed. Paint looks like garbage but the car is running great.
Old 10-04-2021, 02:19 PM
  #1580
1986BANDIT's Avatar
Car: 1986 trans am
Engine: 305/350
$50 barely got me over half a tank ...try canada at $1.60 a liter x 4(aprx) = $6.40 a gallon
Old 10-04-2021, 02:44 PM
  #1581
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
That's about as bad as Europe I think.
Old 10-04-2021, 03:27 PM
  #1582
1986BANDIT's Avatar
Car: 1986 trans am
Engine: 305/350
that was 92 octane,87 is $1.40 a liter or $5.60 a gallon roughly
Old 10-05-2021, 05:06 AM
  #1583
J.C. Denton's Avatar
Car: 85 Iron Duke, 88 GTA and 92 TA
A little less. Over here in germany, the price today is 1,68 euro per liter in my region for 95 octane (which is standard over here, you can still get 91 octane at some places but it is very uncommon and the "worst" fuel you can buy here). 1 euro today is 1,16 US dollar, so 1 liter in germany is 1,95 US dollar = 7,80 US dollar a gallon. The government knows how to rip us with taxes.
Old 10-05-2021, 09:08 AM
  #1584
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
At least our governments agree on that. Your worst fuel rating is our best here w/ 87 octane our lowest.
Old 10-05-2021, 05:05 PM
  #1585
Carlos89's Avatar
Car: 1986 Trans Am
Replaced the water pump and took advantage of it and replaced the thermostat and coolant flush. The WP bearing was bad and dragging the engine down bad, especially with the AC on. Its a completely different drive now.
The following 3 users liked this post by Carlos89:
1986BANDIT (10-05-2021), DynoDave43 (10-06-2021), Moonlight137 (12-05-2021)
Old 10-05-2021, 05:15 PM
  #1586
1986BANDIT's Avatar
Car: 1986 trans am
Engine: 305/350
i really hate taking it on the chin and in the wallet every time at the pumps,now theres some idiotic carbon tax (thanks to second generation political A S S H O L E TRUDOO )THAT DOES NOTHING to alter carbon emissions ,piled on top of the cash grab taxes on top of the income tax,property tax,provincial tax and every other unwanted F U C K I N G tax.....we need a reset
That being said i put air in my front tire today after doing a spectacular burnout for my workmates birthday,car rips like a chainsaw
NoEmissions84TA (10-06-2021)
Old 10-05-2021, 05:20 PM
  #1587
1986BANDIT's Avatar
Car: 1986 trans am
Engine: 305/350
try a decent cam (0.450/0.460 lift) some vortec heads,headers,intake,exhaust and your mind will be blown....i had an LG4,now i have an LG4+++
MIGHTY MOUSE !!
The following 5 users liked this post by 1986BANDIT:
Carlos89 (10-05-2021), dmccain (10-13-2021), DynoDave43 (10-06-2021), Moonlight137 (02-24-2022), NoEmissions84TA (10-06-2021)
Old 10-05-2021, 06:36 PM
  #1588
Evilokc's Avatar
Car: 1991 base firebird
Engine: tbi 305
ive made a bit more progress on the 383 for my 91 firebird. i need to get a fuel pressure regulator and a mini starter and i believe im there.
Old 10-05-2021, 06:38 PM
  #1589
Evilokc's Avatar
Engine: tbi 305
ouch.
Old 10-05-2021, 06:40 PM
  #1590
Evilokc's Avatar
Engine: tbi 305
dude! your car is freaking awesome! what engine , trans, rear end are you running?
Old 10-06-2021, 11:51 AM
  #1591
Carlos89's Avatar
Car: 1986 Trans Am
MIGHTY MOUSE !!
I just need the cam and the heads
1986BANDIT (10-06-2021)
Old 10-06-2021, 02:29 PM
  #1592
1986BANDIT's Avatar
Car: 1986 trans am
Engine: 305/350
it woke my car up bigtime... now i need tires
Old 10-12-2021, 09:45 PM
  #1593
Mvfd5117's Avatar
I purchased it! It is a lot more solid than it looks from the pictures. Not even any rust under the t-top seals. Being all rust brown right now I call it the Turd Bird
The following 2 users liked this post by Mvfd5117:
1986BANDIT (10-13-2021), Moonlight137 (11-14-2021)
Old 10-13-2021, 07:16 AM
  #1594
1986BANDIT's Avatar
Car: 1986 trans am
Engine: 305/350
i called mine the s h i t h a w k.....if i was rocking this ,i don't know what i would call it....
Old 10-13-2021, 12:23 PM
  #1595
x55Cam's Avatar
Car: 1989 IROC Camaro
Engine: 5.7L
@1986BANDIT
Nice work!.
Try a little muriatic acid mixture with water - something like 1:4 to for starters for the overflow/washer reservoirs to remove the yellow - just slosh it around and let
it sit. Then repeat. Worked for me!
NoEmissions84TA (10-13-2021)
Old 10-13-2021, 04:55 PM
  #1596
1986BANDIT's Avatar
Car: 1986 trans am
Engine: 305/350
thank you so much,i will definitely give that a go..i just missed out on a b/n coolant overflow by about 10 minutes locally....was kind of sad.
ive also seen several people incorporate the hidden 4th gen style tanks but have yet to score one.
Old 10-24-2021, 02:25 PM
  #1597
1986BANDIT's Avatar
Car: 1986 trans am
Engine: 305/350
before .....
i finally manned up and threw on the aero-wing...goodbye giant bookshelf heritage camaro wing,hello aero.now its time for the big sleep,snow soon !!!
The following 2 users liked this post by 1986BANDIT:
Clemson327 (10-24-2021), DynoDave43 (10-24-2021)
Old 10-24-2021, 09:39 PM
  #1598
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Looks good!
Old 10-25-2021, 03:49 AM
  #1599
1986BANDIT's Avatar
Car: 1986 trans am
Engine: 305/350
thanks Dave !
Old 11-14-2021, 08:39 AM
  #1600
Carlos89's Avatar
Car: 1986 Trans Am
Replaced the transmission mount bushing. As you can see the old one was shredded. No more shifter bounce on a spirited 1-2 shift. Also feel like shifting into Reverse is easier.
Quick Reply: what did you do to your thirdgen today?
