Mechanical gauge capillary tubing
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Will air in the capillary tube of a mechanical oil pressure gauge affect its reading?
Fe Primate,
In theory, no. Pressure exerted on the gauge by any fluid, either gas (air) or liquid (oil) will casue the bourdon tube to deflect the same amount, and indicate the same reading. The air may act as a cushion, however, and make the gauge a bit less responsive, but the sustained pressure will eventually read correctly.
It's very similar to the air in a well water tank, glycol filled tires, or the air in your radiator. There is the same pressure exerted on the air as the liquid, so any gauge connected to it would indicate the pressure of both. The oil pressure gauge doesn't require a hydrostatic columm to operate, but would likely be a bit faster without entrapped air.
Engine: 383 Carb
Transmission: 4L60
Yeah that's what I thought. Trying to figure out which gauge I'm supposed to believe.
Hotrodboba400
12-10-2019 07:07 PM
Glowsock
09-06-2015 06:40 AM
