New camshaft, stock lifters? Good/bad?
Car: 06 Toyota Tundra SR5
Im getting a comp cam 262h hopefully, and I was wodneirng if it would be fine with the stock lifters? If not I should get some aftermarket oens then right?
if it's a roller cam yes. if not you'll wipe out the cam in the first 20 min. new cam -new lifters. old cam -old lifters in the same place they came out of. or new lifters. new cam -old lifters verry bad kiss the cam bye bye.
do not use new cam old lifters.
in the first minit a new cam/lifter is fired up, the lifters set up a wear pattern.
its only like 150 for the new cam and lifters, so just do that.
yup, if it's a flat tappet cam you need new lifters. I just purchased a crane extreme cam and lifters for $78 from summit, so you shouldn't have to spend too much money.
Roller cams/lifters do not develop a wear pattern (in theory) so it's OK to reuse the lifters with a new (roller) cam. You'll notice that almost none of the roller cams advertised say they come with lifters.
However, flat tappet cams do develop a wear pattern so the lifters need to be replaced with the cam. Again, notice that almost all flat tappet cams advertised include new lifters.
You cannot use roller lifters with a flat tappet cam or vice versa.
Car: Death Mobile
Engine: 666 c.i.
Originally posted by Momar
It wont hurt anything to have new lifters with an old cam will it though?
Well, it is not a stock cam but It has been used. It is still in the same block, and I planned on using new lifters in it. I guess it is my best bet anyway, because I dont know where the old ones went anymore.
Ben
Ben
ambainb
04-25-2016 09:21 PM
Genopsyde
10-07-2015 08:35 PM
