Starts then stalls
Old 04-05-2016, 08:57 AM
stegal's Avatar
Car: 1990 RS, 2002 Chev Silverado
Starts then stalls
Most of the time the car starts and runs fine. Once in a while it will start then die. If you start it again it is fine, Also I find the car will never start on first try but catches right away on second try.
Old 04-05-2016, 10:24 AM
bop11's Avatar
Car: 1988 GTA
Engine: VIN F 305 TPI
Transmission: AUto
Re: Starts then stalls
Could be running the fuel pump on the oil pressure switch, possibly a bad fuel pump relay.
Old 04-05-2016, 11:46 AM
stegal's Avatar
Sounds interesting.
Old 04-06-2016, 03:16 PM
Piston454's Avatar
Car: 1990 RS Camaro
Engine: 400 sbc throttle body
Transmission: world class t5 manual
Axle/Gears: 3.73's, Detroit TrueTrac
O2 sensor could be faulty. giving a bad reading and flooding it out or not giving it enough fuel causing it to die.
Old 04-06-2016, 03:33 PM
stegal's Avatar
MelodyS
Camaros Wanted
06-20-2016 02:45 PM
EastBoundNDown
04-15-2016 08:18 AM
propaintball96
04-12-2016 01:30 PM
Albani
04-11-2016 11:02 AM
xbmx89
South Central Region
03-29-2016 02:14 PM
Quick Reply: Starts then stalls
