86 5.0 TPI Slight engine knock 04K miles, old lady's car
Car: 1986 Camaro Iroc Z T Top
Engine: 5.0 TPI
Transmission: AT
I either have a loose cap or wore bearing???, was wondering if anybody has had any experience just swapping out rod bearing with out a complete rebuild, car doesn't get driven much and probably wont so was just looking to do a quick fix until a later date, Motor runs and no noise at idle or until you reach about 3k rpm's then its just a slight knock.. looking for ideas to see if any one had a good experience just swapping the rod bearings? or any suggestions thanks!
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Re: 86 5.0 TPI Slight engine knock 04K miles, old lady's car
I once bought a 130k mile, '82 Bonneville with a 4.1L that had a wiped out cam sproket for $300. Other than needing a timing chain it was in great cosmetic shape.
Only after I got it running did I discover it sounded like a diesel. Much worse on cold starts. I drove it daily over 100 miles without issues for another 120k.
All this to say that I would just wait until you can fix it proper (if it is in fact a lower end issue).
Car: 89 Firebird//T-Tops
Engine: 5.0L V8/305
Could be wrong but I heard the old 305 engines have a slight, yet consistant issue building up proper oil pressure upon initial start-up and sometimes get a top-end knock until the oil pressure builds-up and gives the engine proper lubrication. I've never heard mine do it, but I suppose it is definitely plausible that could be happening to yours. Hopefully that's all it is.
![thumbs up](https://www.thirdgen.org/forums/images/smilies/thumbsup.gif)
SRKLEGIN
04-03-2016 07:22 PM
