Idle speed
Car: 86 camaro
Engine: 305 5.0L
Transmission: a4
Idle speed
The idle in my 86 camaro was perfect all winter. I have a 305 with the stock 4 barrel carb, and as soon as we started getting some warmer weather, my idle is ridiculously low and depending on the day, it will stall out while waiting at lights but starts right back up. Any insight on this matter would be greatly appreciated. I have a theory that it's the winter blend gas in the warm weather, but if so what could my options be to solve the problem?
Car: 1992 Pontiac Firebird Formula
Engine: 5.0 305 tpi
Transmission: T5 (5 Speed) lol
Axle/Gears: stock posi
Re: Idle speed
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Re: Idle speed
1 Post
Car: 91 firebird Formula 350
Transmission: N/A, working on a t5 swap
Axle/Gears: 3.73 posi
Re: Idle speed
I assume it has a tps but not sure, it does you could check that too. Hard one to diagnose with the info given
