flat camshaft
flat camshaft
Im rebuilding a 350 (86 block when i look up serial number) i pulled the old cam and lifters and im wonderin do i have to go back with a flat cam and hydraulic lifters? If so thats fine flat cams are cheaper anyways im just wondering what cams yall recommend (what lift and what not aswell)
I have 062 vortec heads
I want to add some power and have it pretty lopey
Any suggestions help
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: flat camshaft
You left a lot of information missing, gear ratio,
Compression, target rpm range your looking for,
Max lift of your heads, budget !
You can get a retrofit roller cam
Re: flat camshaft
Im not gonna lie and pretend i know alot about cams because i really dont. I know what they do thats about it. I heard not to go above a .480 lift ill probably just go with a flat cam because theyre cheaper ive been told to use a crane powermax 272-2 i do believe anyone ever use that?
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
Re: flat camshaft
That 272 cam will run well in a 350 and you'll hear it.
If sticking with stockish gears and TC, I'd go a step smaller and forget about lope.
Re: flat camshaft
Well im probably gonna get bigger gears im gonna do more research on compression and stuff but im probably gonna go with the 272
Re: flat camshaft
Anyone have a suggestion on timing gears and chain if i got with the crane power max 272-2?
after cam i just need intake carb and headers and this motor will be done (besides pullys altetnator power steering fuel pump etc.) Yea its gonna take a little bit
Chf.BurninGlass
03-05-2016 01:48 AM
