1986 camaro problem
1986 camaro problem
i have a 86 camaro/berlinetta,had this problem for a very lond time its been parked for 8 years because of this the check engine light is on and the code that comes up ,it is calling for map sensor but cannot find it its not where it should be ,its a shme its a new motor and trans i just wish someone can tell me or show me where this map sensor is so i can fix it and drive it again please some one help me
Re: 1986 camaro problem
Here's a picture of your cars MAP sensor. It's the sensor with the vacuum fitting on it. Should be held on the drivers side firewall by a bracket.
More info / Webpage:
http://www.autopartswarehouse.com/sk...?apwcid=bngpla
