Fuel Pressure Low only on first cold Start.
Car: 2002 Camaro SS
Engine: Built LS
This is on a 91 5.0 TPI. The first start after sitting takes about 4-5 seconds to start. I have a fuel pressure gauge connected and the car will prim too around 30 PSI. As soon as I start cranking the PSI drops to about 20.
As soon as the car starts it jumps up to almost 40 PSI. If I take the vacuum line off the regulator it idles at 43 where it should be.
The pressure takes many hours to bleed off. If I start the car again after the first it starts right up because its still over 40psi at the rails.
The car has brand new bosch 3 injectors from South Bay and new Wix Fuel Filter. Everything else is stock fuel wise.
Any ideas of what cause this?
Car: 00 SSEi / 94 C4
Engine: 231 / 383
Transmission: 4T65E / ZF 6sp
Axle/Gears: 2.93 / Dana 44 3:45
Re: Fuel Pressure Low only on first cold Start.
Weak FP or brush's starting to GO. System holds & maintains Pressure... Initial prime is low.
Car: 2002 Camaro SS
Engine: Built LS
Are you saying the fuel pump is starting to go or the brushes on the starter?
Engine: 231 / 383
Are you serious. I'm sorry. What does your starter have to do with a FP. There is a brushed motor in all FP's
Car: 2002 Camaro SS
Engine: Built LS
Must be having a bad day? It's Friday man cheer up.
Engine: 231 / 383
I'm as cheerful. As can be. You have never seen. Worn carbon brush. Contacts. Sorry, I tried to help you Diagnose
Engine: 231 / 383
Above is a motor from a GM "delco" - FP. When the brush contacts are WORN = intermittent voltage, Thus weak Pump. Happy Friday!!!!! or the wet Magnets can- de-bond from the CAN = Locked up FP..
Engine: 231 / 383
Class.. Dis-missed. See Ya next time...
gunznrosez87
10-14-2015 11:56 PM
