Temp sensor
Car: 1987 irocz28
Engine: 305 tpi
Transmission: t5 5 speed
Axle/Gears: GU4 3.08 g80
Temp sensor
Ok I was actually going to post about my red hot catalytic converter. After doing several searches on here i found that most everyone agreed to much unburnt fuel. Looking at the reasons for unburnt fuel the one that surprised me is the temp sensor. I have a new one but was out of time to putting it on i will do it tomorrow. But i would like to understand how a bad temp sensor can cause you to run rich.
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: Temp sensor
Cold start needs richer mixture. If temp sensor is incorrectly reporting cold temperature while engine is actually at operating temp, computer will respond by adding fuel that is not required.
