93 camaro TV cable - options part numbers
hi. i need to replace my broken 700r4 TV cable. i have a 93 camaro LT1 with a 700r4 (no traction control). I don't want the universal one cable (that screw seting infront of the linkage looks like it'll slip). i've tryed autozone and pepboys and no luck. Would want the OEM stock style, if you know of an online shop that i can get one that doesn't cost an arm/leg that would work.
Also would another year/make/model fit the 93 LT1 / 700r4 setup?
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: check
Engine: check
Transmission: check
Re: 93 camaro TV cable - options part numbers
Third gen Camaro's and Firebird's run from '82 through '92. A '93 being a fourth gen, likely not many folks here know where to get an OEM style TV cable for one.
Possibly search the engine swap forum here, I'm sure someone has swapped an LT1 into their 3rd gen car.
RBob.
RBob.
Thanks rbob. I'll do that
Fred SS
10-12-2015 11:27 AM
[CA] 700R4 trans & parts
6998poncho
09-25-2015 02:56 PM
