Car doesnt run smooth unless
Car: 1987 irocz28
Engine: 305 tpi
Transmission: t5 5 speed
Axle/Gears: GU4 3.08 g80
I am accelerating. Now that i adjusted the tps iac and it idles 50 times better. The problem i have now is it doesnt hold speed limit under 50mph. The worse is 25mph. No matter what gear i put it in it studders so bad you will get whiplash any ideas as to what can cause this? If your on the freeway no problems but through town you have to ride the clutch it will jerk the s*** out of you. Im stumped.
1 Post
Car: 1990 RS Camaro
Engine: 400 sbc throttle body
Transmission: world class t5 manual
Axle/Gears: 3.73's, Detroit TrueTrac
Re: Car doesnt run smooth unless
sounds like the TPS is having a miss-communication with the ECM. might look into that.
Car: 1987 irocz28
Engine: 305 tpi
1 Post
Car: 1991 GTA
Engine: LB9
It definitely could be the wiring. My TPS has a plug that doesn't have the locking latch anymore(new one on the way). There is enough wiggle in the plug that the TPS isn't communicating well with the ECM.
6speedIROC
02-07-2016 02:42 PM
