Emissions Sticker Please
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
I’m in desperate need of a 1989,5.0,TBI, Automatic Transmission, California Emissions Sticker showing the base timing.
The Federal sticker is all I’ve found so I’m going to ask members that have the same car to send a detailed photo of there’s. You must be able to read it clearly.
Thank You,
Ron
Thank You,
Ron
Engine: 4++,350 & 305 CIs
Re: Emissions Sticker Please
I'm from a semi free state still, I thought they were all the same timing? 0degs.
Engine: TBI,5.0
I apologize about starting a new thread with another similar but its time sensitive.
They are "0" degrees that's why I cant understand the SMOG shops here are all looking at the same information and coming up with 6*BTDC for my car. I know the Emissions sticker says "0" because I've looked at several on the internet. I still cant find the reproduction sticker that fits mine exactly though. The reason I need the reproduction is because it will suffice . I only asked for a photo so I have an exact image to compare the reproduction to.
Engine: TBI,5.0
Sorry, the closest I can find is a 1990 Federal emissions VECI. It shows 0° base timing.
Most TPI engines used 6° BTDC as a base timing setting, not TBIs.
Thirdgen89GTA
11-26-2015 11:04 PM
