Battery voltage
Car: 1985 Iroc-z28
Engine: 5.7l TPI
Axle/Gears: Stock
Battery voltage
My guage jumps from 13 to 18 frequently and has been for a while but now it is bouncing from below 13 to just above 8 volts, I'm think alternator but both the battery and alternator are brand new. Could it be a loose ground?
Car: 86 Trans Am
Engine: 305 LB9
Re: Battery voltage
By your gauge do you mean the in dash gauge?
My in dash gauge always reads below 13-12. Got a voltmeter and it was perfect.
Car: 91 Firebird/88 Firebird/91 Formula
Engine: V6 3.1/V8 5.0/V8 5.0
Transmission: 4L60/700R4/4L60
Axle/Gears: 3.23/2.73/2.73
Re: Battery voltage
My gauge is notoriously bad. I have a radar detector that reads the battery voltage. When my gauge displays 8-13, my detector displays 13.9 steady.
Car: 1985 Iroc-z28
Engine: 5.7l TPI
Axle/Gears: Stock
Re: Battery voltage
Yes the dash gauge, my lights will also get really bright then dim and keep doing it, like the voltage goes up and down
Car: 86 Trans Am
Engine: 305 LB9
Re: Battery voltage
My lights do that as well but always stays within normal range. A note is AC is a huge strain on the system, and ac was not a standard option. And AC and non Ac cars share the same alternator.
