Clutch pedal sleeve bushing
Car: 1987 Trans am
Engine: 350 Vortec Stealth Ram
Axle/Gears: 02 SS Torsen Zexel 3.42
Just finished up a auto to t5 swap and notice my clutch pedal had some crazy side to side play. Figured it was the bushings so pulled the pedal and noticed the actual sleeve that goes in the middle is missing. Anyone have an idea on what size this sleeve is? Maybe I can pick one up from the hardware store. Hoping so since this is my daily. Any help is greatly appreciated.
![Name: 90-789_zps52fdfa61.jpg
Size: 32.6 KB](https://www.thirdgen.org/forums/attachments/tech-general-engine/329044d1501295008-clutch-pedal-sleeve-bushing-90-789_zps52fdfa61.jpg)
Car: 1987 Trans am
Re: Clutch pedal sleeve bushing
The pedal assembly was tight but the clutch pedal was slopping all over the place and causing my master cylinder rod to pop off every press. Happen to be looking at clutch pedal pics and saw there were sleeves that go in the middle that the bolt goes through to keep everything nice and firm. Sure enough mine was missing so I was able to grab one from my auto brake pedal
![driving](https://www.thirdgen.org/forums/images/smilies/driving.gif)
