12v when engine is running
Car: 87 GTA Trans Am
Engine: 5.7 350 TPI
Transmission: TCI transmission
Axle/Gears: 4th gen rear end. With 3.83
Does anyone know what wire has 12v when the engine is running? Or how I can get a wire that has 12v when engine is running? Thanks
Car: 1990 Formula Firebird
Engine: 305 TBI (LO3)
Transmission: WC T-5 out of an 88 T/A
Axle/Gears: 10 bolt, 3.42 & Torsen Posi
Re: 12v when engine is running
There are probably 100 wires that are hot when the engine is running. What area of the car are you working in? What are you trying to power? What kind of amperage do you need to power whatever your trying to put in?
Engine: 5.7 350 TPI
Amperage= doesn't matter about the amperage because I'm gonna just use it as a signal wire for a relay
Engine: 5.7 350 TPI
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Engine: 5.7 350 TPI
Engine: 5.7 350 TPI
http://m.summitracing.com/parts/hly-12-810
Can this work for turning on the fans when the engine is running? It will normally be open and when the engine is running pass 5psi it will close the circuit and send power to the fan relay? Do I have this correct? Can this pressure switch do that?
Thanks in advance
Thanks in advance
Engine: Lb9
Transmission: M20
If your dead set on ahortening the life of your fans and hacking up your wiring you could install a acdelco D1818 gm 25036553 oil pressure (4 PSI) (runs fuel pumprelay fails)
Switch, oil pressure (4 PSI) to control a relay.
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
Why are you wanting to bypass the fan switch?
Engine: 5.7 350 TPI
If I use that switch the fan won't run when the engine is started. The switch opens when the pressure rises above 4psi? Or does it close? If it closes that would be perfect! But if it doesn't the fans will never turn on when the engine is running
Engine: 5.7 350 TPI
I bought the car with the dual fans running off of the coolant temp sensor on the passenger side head and when the engine is warm and I turn the ignition on the fans run all the time. So me and Tuned Performance are trying to figure out how to get the fans to run only when the engine is running
Car: 1987 iroc
Why not just wire in a toggle switch then. You can turn them on and off at your discretion. When the car is running down the road at speed, you don't need them on anyway. Or a new switch, http://www.autopartswarehouse.com/sk...0-80e2d0037ec1
Engine: 5.7 350 TPI
Engine: 5.7 350 TPI
Car: 1987 iroc
How about a new switch i posted in #17 above
Engine: 5.7 350 TPI
If you're really set on doing this why not ponder this, install the oil pressure switch, but wire it in line with the existing coolant temp switch in the head, then the fans will only run when the engine is running AND hot.
That way your not putting a bunch of extra stress on the fan motors running all the time when they don't need to be. Add a few more years to their lifespan.
db057
08-11-2015 10:11 PM
