what is suggested to have when replacing a fuel pump
Car: 1987 camaro
Engine: 305 V8 LG4
Transmission: 4-speed automatic
Im finally on the verge of replacing the fuel pump in my 87 Camaro and want to make sure I'm well prepared. What parts, if any, do I need other than the fuel pump replacement? Does it matter what brand I get of fuel pump. For example I saw one for 54.99 and then I saw a high-performance one for 152.99. Will the cheaper one work just the same?
Car: 1988 Camaro
Re: what is suggested to have when replacing a fuel pump
Block mounted mech. fuel pump or in tank elec. fuel pump?
Car: 84 z28/ 79 trans am
Engine: 305 LG4/pontiac 301
Transmission: T-5/th350
Axle/Gears: 4.10s/3.42s
i just got a oem ac delco replacement mech fuel pump... just make sure you have lots and lots of grease to hold the plunger in place cause its a bitch to pull back up into the correct position
Car: 1988 Camaro
Look on the front pass side of block at bottom. You will see 2 bolt holes. One on top of the other. The top hole will have a bolt in it.
Remove this bolt. It will be very short. Keep it safe.
Thread in a longer 3/8" thread bolt into that hole. Snug it up but don't force it tight. This hole is open and goes straight to the fuel pump rod.. A long bolt will hit the pump rod, so by snugging up a longer bolt will hit against the rod and hold it in place for you.
Car: 1987 camaro
Engine: 305 V8 LG4
I appreciate the feedback guys. Just ready to hear her start and stay running. I'm just hoping its not as big of a nightmare as most people say it is. Lol. Would I be better off converting to an out of tank pump or would it go smoother just putting another one in the pump??
Car: 1987 camaro
Engine: 305 V8 LG4
Currently its in tank pump but would it be easier to stay in tank pump or block mounted?
Car: To many to list
Keep the in tank pump. No reason to make that change. I would get a GM or delco pump. DO NOT go with a cheap parts store pump..
Car: 1987 camaro
Engine: 305 V8 LG4
Are the delco fuel pumps pretty universal or do I need a specific one? Wheres the best place to pick one up or order online?
Car: 1988 Camaro
In the tank pump is not an easy, fast job, but it can be done.
Do not cheap on on that pump. GM/Ac delco for sure.
Check rockauto.com
Check rockauto.com
Engine: 4++,350 & 305 CIs
Step 1
Cooler, beer and ice.
Step 2
Enjoy
Step 2
Enjoy
I just did this job on my 91. The rumors are true...not fast, easy or fun. It helps to have a buddy to lift the tank back in place and help guide that d@mned filler neck. Do a little search. There are a couple of great step by step articles on this job.
goalieforlife (08-12-2019)
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
If you're plan on doing future mods get the high performance fuel pump for $153.00. You don't have to worry about later when you start modding.
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
For the Fuel pump I recommend the AC Delco fuel pump used in the Typhoons and grand nationals part number is EP381. I use it after the good report/advice/findings of Dyno Don. It is a complete bolt in. Three years so far.
92camaroJoe
08-13-2015 06:07 AM
