adjusting transmission cable
Car: 89 IrocZ
Engine: L98-ish
Re: adjusting transmission cable
nEVER DONE IT ON A CARBED tv cABLE, BUT ON tbi AND tpi. YOU PUSH THE SQUARE BUTTON IN, PULL THE CABLE OUT, THEN MANUALLY OPEN THE THROTTLE TO wot...YOU'LL HEAR A FEW CLICKS...
tHEN ALL IS GOOD.
Aw, FFS Caps was on...to lazy to retype it
tHEN ALL IS GOOD.
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
https://www.thirdgen.org/forums/tran...djustment.html Let your finger do the walking.
Car: 86 Trans Am WS6
Engine: 383 stroker
Axle/Gears: 9 Bolt 3.45
Push the button and slide the plastic all the way back(torwards the firewall) and then sit in the car and press the pedal all the way to the floor. The button can be difficult, you just got to squeeze with all your mite.
