37 or 45 degree flare for this adapter
Car: 89 GTA
Engine: 6.0L Procharged
Axle/Gears: 4.10
I want to cut my stock 3/8" and 5/16" fuel lines near the transmission and convert it to 6AN line there. I'm looking at these adapters to use:
http://www.jegs.com/i/Earls/361/9919...rentProductId=
Question is, do I flare the stock lines with double 37 or double 45 degree for these adapters? I was thinking 45, but I can't find this info anywhere.
Car: 88GTA
Engine: 5.7TPI
Re: 37 or 45 degree flare for this adapter
Check out Allen Aircraft in North Hollywood. They have EVERY fitting under the sun.
Car: 89 GTA
Axle/Gears: 4.10
So you are saying the adapter I posted is meant to mate with a 37 degree flare? I was unsure about this because this is the adapter you use to mate up with your stock hydraulic lines and I thought they were all SAE 45 degree.
Car: 88GTA
Engine: 5.7TPI
It depends on the adapter. If you ask them for a 37, flare your line to that. If it's normally a 45 (and I am not sure on that) use a 45.
I think I just wasted your time...........sorry.
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
An is always 37 degrees. Hydraulic is different and usually 45
Car: 89 GTA
Axle/Gears: 4.10
Thanks, I found this helpful picture. I bought a 45 degree double flare tool for $80 and will be using the Earls adapters to go to AN fittings.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I use one of these to make my 37* flares. Tool #377. It's not a cheap tool but even a blind person could make a perfect 37* flare with this tool.
https://www.ridgid.com/us/en/precisi...ing-flare-tool
Engine: 4++,350 & 305 CIs
You need something like this.
Or this
Or this
RedLeader289
05-28-2019 01:47 PM
