Rear end help
Car: 89 IrocZ
Engine: L98-ish
Re: Rear end help
Look for a tag (s) on the rear...or look for your RPO codes-should be under the glove box lid (is on my Camaro) for the ratio(to decipher).
Gear oil is kinda dependent upon preference...85-120, 90 wt, etc...a lot depending on driving habits..I/e you take long trips, or is it a grocery getter?
If it has posi (will be evident by have two tags on the rear end cover if unmolested) you may need to add a GM friction mollifier if your oil you buy doesn't have it...most don't.
hectre13
12-11-2023 08:14 AM
hectre13
08-26-2015 08:17 AM
AkDrifted
08-17-2015 07:45 PM
