Steering column loose.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Steering column loose.
Take note that there aren't many questions that haven't been asked and answered, so a search will frequently be a benefit.
For the issue at hand, start with the following link:
https://www.thirdgen.org/forums/susp...-steering.html
Best of luck,
JamesC
Car: 1987 Trans Am GTA
Engine: Warmed over 350 TPI
Transmission: 700r4 soon to be t56
From what it sounds like, you have everything disassembled up the the tilting pins. If so, you'll need a special tool which screws into them and pulls them out (a pin puller?). Once that is done, if I remember correctly the upper part of the column should come free. You should see four bolts in the center that are very loose, take them out, clean them off, apply some thread lock and put them back in.
There are a lot of articles out there and there are some videos explaining how to do it. Almost all GM steering columns were the same 'till the mod 90's, so any video with one of the gm columns should work.
Hope this help, and good luck.
sjorgens
10-01-2015 07:54 PM
