305 with 5 speed or 350 with automatic
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
Re: 305 with 5 speed or 350 with automatic
No brainer. Go 350 then. If it was a tpi 305 you would have a tougher decision to make
I'd take the 5-spd car.
Easier to change a 305 into a 350, than an auto car into a stick.
Matter of opinion though; you'll get plenty of valid points either way.
Car: 72 nova/ 90 camaro rs,04 suburban
Engine: blown 327/ 355/306/355/5.3
Transmission: muncie 4 speed/T5/powerglide,4l80e
Axle/Gears: 342/411/456/ moser axles
it depends on wether you want a TPI car or a carbed car, carbed has no limitations on building an engine, TPI does have limitations, if you just want a daily driver, then I would go TPI
Car: 88 Firebird Formula
Engine: LO5 5.7 TBI/Ebl Flash
Axle/Gears: 2.73 stock rear end
Although the 350TPI sounds great to me, so does the 5speed!! They both have ups and downs. But as others have said if going to make a DD out of it go with the TPI, if going to street rod it go with the 5 speed. Although the tpi isnt a bad starting area either......... LOL it can go either way!!
Car: 1998 Camaro Z28
Engine: 6.0L
Man, tough decision. In that case, an auto to manual swap may be easier to do. If you are going to stick w/ a carbed engine though, i may lean toward the 305. If you prefer TPI, it would be easier to swap a manual in than it would be to convert from carb to TPI. I guess it would also depend on the year of each car, miles, body condition, engine/trans condition of each, etc. I'd compare everything about the two, not just the engine/trans combo and decide. You dont wanna buy one w/ the driveline you like, but have to do a ton of body work or something like that.
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
Are the cars in similar cosmetic condition?
Engine and trans work is easy. Replacing/fixing worn out paint, trim and interior plastic parts is a PITA and not usually cheap.
Are you going to drive the car as-is?
If so, I think it's a toss up.
Will you ever want more power in either of them?
If so, then the carbed car is the hands down winner. You can put a much stouter long block underneath the carb and it will handle it. Not so with the TPI.
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Get the nicer car.
I'd be leary of an LG4 car... it may be a 5 speed and thats cool but the LG4 is truly awful. Uprading that to something better will mean the 5 speed has to go too. Meh.
Im all about 305 TPI 5 speed cars... but LG4 cars are snore inducers for me. You can put a stealth ram or something under all the TPI parts if you really wanted, not that big of a deal. Just a matter of tuning it.
Car: 1992 Camaro RS
Hold on a minute. If you're gonna swap to a T56 I'd go with the 5 speed car every time.
it wouldn't be worth changing to a t56 for a 305 tbi. he would have to change the engine TOO to make it worth it. he's a lot closer to where he wants to be with the 350 tPI, and then an eventual auto to manual swap
colton_carlson
03-08-2019 12:21 PM
