355 recipe for mid to high 12 1/4
Car: 1987 iroc z
Engine: 305 tpi for now
Axle/Gears: 3:24
355 speed pro flat tops
eagle crank 3.48
10.7:1
comp xe284h flat tappet
headman long tubes with purple hornies 3 inch collectors, side exit
edelbrock 750
vortec heads
air gap intake.
5 speed
4:11 10 bolt
going in 86 z.
295 50 16 M/T drag radials
shooting for 12.20-12.80
eagle crank 3.48
10.7:1
edelbrock 750
vortec heads
air gap intake.
5 speed
4:11 10 bolt
going in 86 z.
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
Re: 355 recipe for mid to high 12 1/4
Maybe...thats a fair amount of cam in a 350
If theres any weak spots its the heads all you can do is try it go from there
Car: 1987 iroc z
Axle/Gears: 3:24
may go with the xe274h more torque than the 284. not much of a hp gain with the 284, just sounds nastier and last time i checked sound dosent win races. lol
These guys push the envelope with miss matched steel heads and then post about issues they are having.
![idiot](https://www.thirdgen.org/forums/images/smilies/idiot.gif)
Best recent bud to me(I do really mean that)is Skinny dealing with the same thing.
Ya know if it doesn't make sense,then it isn't sensible.
![nod](https://www.thirdgen.org/forums/images/smilies/nod.gif)
You will probably have to work over the vortec heads a bit for that cam. A light port and polish should help them at max lift.
True, everything is a package but alot of builds seem to get thrown together and then have to deal with it.
If you build high comp and need big cam, you better be willing to turn it to the rpm that cam works in, and better have the heads/intake to support it, or else you are wasting power.
Vortecs arent ideal to feed the big cam but the combo can work. You just end up with a flat hp curve across large rpm range and that requires you to turn rpm and add lots of gear ratio to use it.
I think the esxhaust port would be your first limitation. At minimum it would need a good porting and a 1.6 valve.
A better plan would be to look into bowtie 185 or maybe 225cc vortecs.
Maybe even one of the after market 185cc vortecs.
Car: 1987 iroc z
Axle/Gears: 3:24
You do know the Eagle's are tons less than a GM forged steel which in the long run and updates you currently haven't planned on,the GM steel would handle easily.
Note-no comment or advice on good aftermarket cranks.Eagle doesn't have a good track record.
Hotrodboba400
12-10-2019 07:07 PM
codeysabatini
11-10-2015 04:07 PM
