Fuel, no start
Car: 1985 Camaro
Engine: 2.8
Transmission: Automatic
Fuel, no start
Hello, new to Thirdgen, I have a 85 base Camaro with an 2.8 V6 w/auto. It sat in a garage for eleven years before I obtained it. Got it running and it ran fine for a few months then it quit. It acts like it wants to start for a split second but then just turns over. My suspicions are a clogged fuel filter or bad fuel pump. Or could it be a fuel pump relay ? If it is the fuel pump I have heard it can be difficult to replace. Any help or ideas will be appreciated. Thanks.
Car: '82 TA GT1 Roadracer
Engine: ZZ4 Fast Burn 385
Transmission: TEX101A Dog Box
Axle/Gears: 3.73 4th Gen w/Auburn Racers Diff
Re: Fuel, no start
I suggest you use the search function. There are a few long threads on this topic,
and most of the time they involve replacement of the pump, which can be a nightmare if you are doing it for the first time without experienced help. There is a known issue with a short rubber feed line on the pump assy. that simply goes rotten with age, and yours may be due! Find someone who has done this kind of work (successfully!) before.
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Under Suspicion
Did you measure the fuel pressure?
Do you hear the fuel pump prime when you first turn the key to the RUN position?
Happy Racing!
Short Tracks Can Sometimes Be The Longest Races
Happy Racing!
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Under Suspicion
https://www.thirdgen.org/forums/tech...formation.html
Did you do a complete clean out of the whole fuel system before running it ?
Gas doesn't last for ever and goes " off " causing many problems
Until you determine if you have any fuel available at the engine and at what pressure ;everything else is a random guess at to what your problem " may be "
Car: 1985 Camaro
Engine: 2.8
Re: Fuel, no start
No I just siphoned out what was left. It was clean. Probably not the best thing to do I know. Ran fine for a few months. Will run the pressure test. More than likely its the pump. It doesn't make a noise when I turn the key on as before.
theshackle
03-05-2017 06:37 PM
92camaroJoe
08-13-2015 06:07 AM
