Simple: Bolt/Tool accesss & turn dizzy
Car: 1988 Iroc-Z Red T-tops
Engine: 305 TPI LB9 55k miles
Transmission: Auto 700r4
Axle/Gears: 2.73 posi
I see the dizzy bolt looks like 1/2 or bigger on pass side behind plenum. It looks like i am at 3deg advance base idle for 88 tpi lb9 auto.
the prom has 6 deg in the bin. so I want to adjust and it is running rich (think the MAF is off too)
What is best tool to losen and turn it appears hard to get a wrench or socket in the there?
Also side note. PO has spliced in wires across the coil (next to the dizzy?) going into the cabin. it is the white wire coming from the coil. What would this be for typically?
83 Crossfire TA
09-08-2015 12:06 PM
