help me pick a cam
1 Post
Car: 1984 chevy camaro
Engine: 355
Transmission: turbo 350 2800 stall
Axle/Gears: 3:73 detroit locker posi
help me pick a cam
the current cam i have is not really what im looking for. im on the market for a new cam to help "level" out my mismatched combo. anyone with input please help! my goal is a 12.99 and lower street car. thank you in advance!
350 0.30 over- 55235 APRROX MILES
210cc aluminum heads 2.02/1.60 valves- PRO COMP.
Roller rocker arms-3/8 1.5 RATIO
Edelbrock cam .488/510 duration is 230/240-FLAT TAPPET
Air gap intake-MATCHED PORTS
Msd ignirion
14* base timing
Hooker headers to true duals- HOOKER HEADERS 25/8 PRIMES TO 3 INCH
Stripped interior of anything usless
Procar racing seats
7.5 TEN BOLT WITH 28 SPLINE MOSER AXLES C CLIP ELIMINATORS
3.73 gears- DETROIT LOCKER
275/15 rear drag radials
Turbo 350 trans
2800 stall-
STOCK SUSPENSION WITH FRONT SWAY BAR REMOVED
UNSURE COMPRESSION MAYB 9.8-10.1ISH
Msd ignirion
14* base timing
Procar racing seats
Turbo 350 trans
2800 stall-
Re: help me pick a cam
Got a part number for that cam?
Also ditch the pro comp heads.
With the full edelbrock kit it makes about 400hp at the flywheel.
I will have to think about a good cam for those heads. They don't flow much until they get over 500 lift and even then they flow poor for 210CC heads.
http://www.store.procompelectronics....oduct_id=37062
With your build what is your max RPM?
Car: 1984 TA - 17k orig miles
Engine: 355
Axle/Gears: 3.44 Dana 44 performance rear
Really need to know what the compression is to pick a good cam. If you're running stock pistons or worse yet "rebuilder's" pistons you're going to be WAY down from that compression number - which is going to kill power potential
With those heads on a 'small' 355" engine it's going to take a high lift cam with some upper RPM's to get any respectable power out of them - which is what I think you're finding out...
The head ports are way too big for a (primarily) lower rpm street engine as with any large runner head the low RPM port velocity suffers and flow suffers.
If ditching the heads aren't an option - then how about building more compression with a small dome piston then running a 3800-4500 stall converter and a good solid flat tappet cam (something like a Lunati 30120919 a Doug Herbert HERCC5R, or one of the circle track grinds actually work well - the summit CT-109 is actually a pretty decent inexpensive cam if you can't run a solid roller...)
That cam is fairly large for your motor. Good for high rpm like you said but below 3000 its gonna be rough. It has lazy lobes so there goes your low speed vacuum and torque/driveability
Given your converter and goals, i would step down to a comp xe or lunati voodoo series around 268-270 adv duration which will give 224-227 at .050. Order on a 108-110 lsa
It will give you good vacuum, and work with those heads and converter. Thats the largest cam i would run in that setup. It will turn 6200 rpms fairly easily. Anything more than that you would want a 276 or so cam and 3500+ stall to run best
Heads have a big cc port but the valve size is small so it should still give decent low and mid range just need to cam it right
This might work out for him but I am thinking he will want to get over 500 lift with those heads.
http://www.summitracing.com/parts/cc...make/chevrolet
1 Post
Engine: 355
Yea unfortunately you will need to stick with a higher RPM cam. Those heads only flow about 230CFM at 500 lift and with 210cc chambers that will be rough. So you will be limited by how fast you think you can spin your engine.
1 Post
Engine: 355
1 Post
Engine: 355
1 Post
Engine: 355
ok cool. now if i replace that cam with the comp cam shown in the post would i be in my range for 12s? say if i got a higher stall 3200-3500 with the current cam would i be in the 12s? just trying to see what "makes sense" rather then rob peter to pay paul
If he plans on spinning to 6500 think the XE284 would be a good choice?
http://www.compcams.com/Company/CC/c...x?csid=88&sb=2
Or stick with something a little smaller like the 274?
http://www.compcams.com/Company/CC/c...x?csid=87&sb=2
274 for 6500 max but i'd still consider the next size down if you want to keep 2800 stall and have much better street manors
268xe plus the rest of that combo will run mid 12's easily.
Car sounds light and on good tires with a th350... Should launch solid. Keep the low stall for street driving and the smaller cam. Compression isnt high enough to run much more than 268-274 deg cams. 350's start to get alittle lazy with 230 deg cams at .050, much like how ls1 motors are. They need 3600-4000 stall to really move
With a manual I find that trans perfectly streetable. Now I just need to get rid of my locking rear and get a real posi.
1 Post
Engine: 355
thanks for the help guys. so im going to go with the 268xe cam do you have apartnumber for that by chance. im going to run and see what this cam does and over winter/fall im gna yank the cam and put in new one. cant wait to hit 12s, then ill be content.........for now.
http://www.compcams.com/Company/CC/c...x?csid=86&sb=2
1 Post
Engine: 355
havent ran it yet i never raced and kind of embarassed to go and test if it runs like a 14 or something which it shouldnt..
1 Post
Engine: 355
also totally off subject could my tranny shifting to soon cause a horsepower lose feel? if i cruise itll shift all through the gears by 45mph. when wot it shifts quick. not sure if i should change the governor springs or leave her be
Well the 268 and 274 should do alot better as far as idle and vacuum go, with the 268 providing the most. Both are capable of 12's. 274 fits the head siZe better but converter would be better suited to the smaller cam unless you restalled it. Probably not needed for a street driver and a 12 sec pass. A 274 cam on 2800 stall with good timing curve should leave hard enough to get 12's.
I'd still try to get a baseline where you are at currently. Dont be embarrassed if it is a turd. It happens. You are working in a new setup so it takes time.
Cant go wrong with either cam 268-274 if you swap them out, both i consider better than what you have. 1.6 rockers and proper springs for the cam should be considered too. You will get your goal in good air.
1 Post
Engine: 355
1 Post
Engine: 355
reaction- .4829
60 ft- 1.9999
330 ft- 6.0132
1/8 et-.93281
1/8 mph- 74.39
1000ft- 12.16
100 mph- 85.91
14.5797 1/4 et
90.65- 1/4 mph
is this the result of the stupid cam? it has no "launch power at all" but getting in the power band for the cam is really noticeable. also im getting some oil out the spark plug holes, would pistons leaking cause an issue in performance also?
Was that the current cam 230/244 in the original post?
If you are feeling the motor come into its power band hard then you dont have enough converter. The rpm you feel the motor really start to pull hard you want the converter to be withing a few hundred rpm of that point
Also that mph is way low. Sounds like motor isnt making any power and is really hurting somewhere. Has any carb tuning been done?
ok ran the car last night and got some really **** poor results.
reaction- .4829
60 ft- 1.9999
330 ft- 6.0132
1/8 et-.93281
1/8 mph- 74.39
1000ft- 12.16
100 mph- 85.91
14.5797 1/4 et
90.65- 1/4 mph
reaction- .4829
60 ft- 1.9999
330 ft- 6.0132
1/8 et-.93281
1/8 mph- 74.39
1000ft- 12.16
100 mph- 85.91
14.5797 1/4 et
90.65- 1/4 mph
Ouch, that is about on par with my winter toyota. Either way not every pass is a keeper.
There are 3 things holding you back.
Your stall, cam and heads
Your cam and heads are not designed for low RPM performance. Your heads flow similar numbers to vortec heads but not nearly as well down low and their chambers are huge 210cc vs 170cc. Big ports and poor flow = bad low end.
So you have heads that want lots of lift and RPMs, a stock stall and a cam not really matched for either.
Code:
Stock 210 CC procomps 2.02 / 1.6 Valves Exhaust Flow .100 52 .200 97.8 .300 132.9 .400 161.9 .500 180 .600 189.2 Intake Flow .100 63 .200 117.1 .300 163.10 .400 203.55 .500 230.3 .600 248.2
Code:
Stock 170cc Vortecs 1.94 / 1.5 Valves Exhaust Flow .100 44.3 .200 93.3 .300 125.1 .400 140.5 .500 144.1 .600 146.1 Intake Flow .100 63.2 .200 127.1 .300 178.1 .400 212.1 .500 228.9 .600 224.5
1 Post
Engine: 355
1 Post
Engine: 355
Code:
Code:
If your going to address the pistons issue,might be a prime time to go 383 stroker.Well really it would be 388 with a bigger fresh bore.That way you could better use the heads you own and cam it accordingly.
I do think what you found out is in part is in line with what I have been telling guys for yrs.These engines being a air pump,is a systems approach where matched parts is critical.That the days of slam parts and go are long gone.Well really that and the fact of blow by which is really hurting you cause not having a solid bottom end.
Another way of looking at this is to buy a L31 block and build up a hydro roller 388.Sell off your short block to off set the extras costs.
In either case shoot for a target quench of .040 to .035.That does help a ton to run pump gas and will wake up your engine's build.
1 Post
Car: 1988 Camaro
Engine: 377
Transmission: TH350; Circle D 4200 converter
Axle/Gears: Ford 9"
You've got a host of issues going on.. You can replace parts ALL day long and waste cash doing it if you're not careful. Your current cam and converter can run halfway decent times as long as everything else is in order.. The problem is those heads stumble ALL the way up to their good/usable range, and the port velocity (and your current compression in conjunction) are absolutely killing you.
I'm on the fence as to what to tell you since you're on a seemingly tight budget. What kind of cash are you working with? The last thing you want is replacing parts where it's not needed.
1 Post
Engine: 355
absolutely agree with you on that. I really cant afford to purchase new heads at the moment, but I am going to by a rebuild kit and rebuild the motor. the fact that I thought it was fuel fouling out my plugs, actually turned out to be oil, and to me a lot of it. it covers the heads below the plugs, so I know that's a issue. so all im asking is im keeping the current heads is to point me in the right direction with a cam and possibly a convertor (everyone has helped me ALOT so far and I appreciate it.) so if the cams listed above will work ill purchase on of those to, and a higher stall.
#42
1 Post
Car: 1988 Camaro
Engine: 377
Axle/Gears: Ford 9"
That's obviously a given, I am merely coming from the same angle as Gary in the "since its still apart..." way of looking at it. The question really lies in how much he is wanting to throw down on the project. Fixing the obvious problem present is the first step (and arguably where a huge chunk of the problem is along with the tune is my guess), but I still think those heads are holding him back from what he COULD be doing, particularly in mid lift numbers. No cam will fix that.
#43
1 Post
Car: 1988 Camaro
Engine: 377
Axle/Gears: Ford 9"
#44
1 Post
Engine: 355
Fix the motor issue first that way you push all your critical funds in one spot as opposed to spreading it out and not isolating your changes in one area at a time.. Run it with the current setup and see how it rolls once everything is fixed. What type of converter is it?
#45
1 Post
Car: 1988 Camaro
Engine: 377
Axle/Gears: Ford 9"
its a flashed convertor from Vickers transmissions in alliance ohio. he said it was a 2800 stall but when I got to launch at 2500 it starts to slide the car forward while holding brakes. so I think its a 2500 stall? I hate to repair the motor keep current cam if it needs switched and have to pull the motor apart again to do the cam. wouldn't it be "wise" to change cam while motors out?
There's a lot of stuff you can run cheap on, but a torque converter should never fall under that category. Do the other stuff RIGHT so you're not wasting money doing a juggling act.
#46
1 Post
Engine: 355
Well, yes and no. You'll need another converter if you go much bigger on camshaft profile. If youre going to buy another converter, you absolutely should NOT buy another 'shelf' converter.. You've already done that once. which means: $800-1200 for a torque converter. save your cash and do it right, or just hold onto your money. That cam is more than capable of reaching your goals assuming everything else is working as it should. I personally wouldn't change the cam if you're on a massively tight budget, but that's just my opinion. If you plan on buying a new converter then yes, now would be a good time to do it.
#47
1 Post
Car: 1988 Camaro
Engine: 377
Axle/Gears: Ford 9"
true. but leaking piston rings can cause that much of a performance loss? im new to building motors so if I should "stupid" that's why. so basically saying I should fix the pistons and leave everything else alone and tune the motor and I should have my 12s motor? or am I missing the concept of everything?
What's your budget? If you're going to tear into the bottom end like you should, now is your perfect excuse to build a stroker if you've been looking to do that. Do you NEED to build a stroker? Nope, you don't.. and certainly not to hit 12's. Is it one of those "I should've _______ while the motor was out of the car" questions? Yeah, probably.
It all comes down to how much time and money you've got.
#48
1 Post
Engine: 355
Some of the most seemingly minor details often have the greatest impact on how anything mechanical operates. It's not a stupid question; it's a very valid one.
#49
I would have the bore rehoned if possible with new rings. Break in properly and double check everything from assembly. Make sure you adjust lifter preload properly, and have proper pushrod length.
If you were going to spend money i'd do a hyd roller conversion with new valvesprings. 350 is plenty for 12's, you just need to find out why the parts you have are not making power. ET is one thing but mph is low and thats not a cam and converter issue by themselves. I am not sure bad ring seal would kill 100-150 hp you are missing either. Something isnt right
#50
1 Post
Engine: 355
