92 z28 fuel pump help
My tank...sending unit...bbk hi flow fuel pump are 3 years old and under 1000k miles worn in. Here is the prob. I put a c6 brake kit on...adjustable prop valve, and a new rear end in, and alternator. I'm mentioning this cause maybe during my install I got fluid on the relay or did something putting the rear back in. Car needed jumped to be started. Car drove normal but if I kept it at constant rpms it would hiccup just a little. Well pulled up to a light and it died. Would crank but not start. I pulled the fuel filter off and cranked the car. No fuel shifting out period. I am awaiting my new fuel relay but a little uncertain on how to test everything other than assuming that my under 1000k fuel pump is bad. Any suggestions or help on how to test this? Dropping the tank again won't be something I want to do unless I am 100% positive its the pump. Thanks for all help and suggestions.
92camaroJoe
08-13-2015 06:07 AM
